Starter won't turn over or click
I have a 1999 Dodge Ram 1500 with a 5.2L automatic. When I turn the key there is no click or any sound from the starter and it doesn't turn over. The battery is good. All grounds are good. I pulled the starter and had it tested and it turned right over and tested good in the store. I reinstalled the old starter. I checked and swapped the fuse and relay. I changed the neutral safety switch and the ignition switch and still nothing. I have not changed the key lock cylinder yet. Does anyone have any ideas before I throw more money at this?
I used a test light on the slots the relay fits in. The 30 slot had power all the time. There are 85, 86, and 87 slots and none of those had power when the key was in the run or start position. I didn't use a multimeter if that makes a difference. I also didn't check to see if any went to ground because I'm not sure how to do that.
