Need advice on new motor
Old 10-03-2024 | 12:16 AM
Moved To TN's Avatar
Moved To TN
Default Need advice on new motor
Hello new guy hear with new to me 1991 Dakota 5.2 2wd auto. It is a Southern rust free relatively straight body truck but has a locked up motor I have tried but cant turn crank with breaker bar, the coolant mixed with the oil so motor is shot.She had 250,000 miles on her anyway. The good news I have receipt for 1875.00 dollars spent on transmission It came with a brand new Holly Sniper EFI on a new Edelbrock performer intake brand new distributor and new set of headers so with all the goody's I couldn't pass it up. My question what year motors will work as far as bolting to trans and motor mounts or would I be better off having the block and heads I have rebuilt it does have a roller cam already. If I go that route any upgrades i should look into Thank in advance for your help
Old 10-03-2024 | 09:30 AM
Is it a magnum motor in there? (intake manifold bolts go straight down into the heads, instead of at an angle.) 92 was actually the first year for the magnum.... but, I suspect yours has been swapped.
Old 10-03-2024 | 12:29 PM
Moved To TN
The bolts go at an angle so i guess that would make it a LA engine
Old 10-03-2024 | 03:27 PM
Interesting.... Is it an aftermarket roller cam in there?? I don't recall just when the 5.2 went to rollers.... I thought that was with the Magnum engines only......
Old 10-03-2024 | 07:57 PM
Moved To TN
I did read somewhere that some of the 91's had roller cams also read the the motor mounts are different I think I would be better off getting mine rebuild. You never know what your getting on a used engine. I plan on pulling it out tomorrow and see what happened maybe its not to bad lol.
Old 10-03-2024 | 09:21 PM
Hope springs eternal.
tndakman (10-04-2024)
Old 10-06-2024 | 07:15 PM
ol' grouch's Avatar
ol' grouch
The LA 318 and 360 went with roller cams when they went with fuel injection.
Old 10-06-2024 | 07:30 PM
87 or so then??
Old 10-06-2024 | 07:33 PM
ol' grouch's Avatar
ol' grouch
87 or so then??
1988. I meant to add that but hit send too soon.
