Sheared cab bolt - how to remove and replace???
I have a 2006 single cab 2500. I hit something the other day that broke off the rear driver side nut and bolt that holds the cab to the frame, and my running board to both. I am wondering how to get the bolt out. I reached in through a hole in the frame above the bolt and it felt like there was a nut welded to the frame the bolt is threaded to. Has anyone removed this bolt? What's the best way to approach its removal. See the pics for orientation. the last pic is of the front cab bolt and how the running board is attached to the frame. Thanks.
