Depending on how much you want to spend, if you want a transmission to swap out the one you have, you might want to consider a used transmission - if so, check car-part.com for salvage yards in your general area that may have one available. If you want to spend for a new transmission fully beefed up, you can opt for a MegaViper from these folks - https://transmissioncenter.net/shop/...-viper-series/
