Fuse Box on 1990 Ram B350
Old 10-27-2024 | 08:23 PM
SteelVenom11's Avatar
SteelVenom11
Default Fuse Box on 1990 Ram B350
There is one fuse holder in my glass fuse block that was melted in my van. Could someone putting in the wrong fuse create a bad connection causing this? I came across a replacement block, but would it be worth wiring in a new one?
Old 10-27-2024 | 08:57 PM
ElkCon's Avatar
ElkCon
absolutely...
evidently the connection wasnt tight enough -- more than likely...OR that circuit had a really high draw very near the blow point of the fuse...for a very long time...
SteelVenom11 (Yesterday)
Old Yesterday | 01:44 PM
SteelVenom11
In that case, would wiring in a new one be the best option?
Old Yesterday | 02:46 PM
ElkCon's Avatar
ElkCon
a new circuit yea---i dont think you need to do the whole box unless you want to...You have to remember we are dealing with used parts...if you have a part with possible multiple points of failure...and only one is failed - they just fix the one...
Used parts can be an issue..especially electric ones
Old Yesterday | 06:23 PM
SteelVenom11
The two janky fuse holders aren’t entirely important to the functionality of the car, but it would be nice to get them fixed.
Old Yesterday | 07:57 PM
Wow, that's burnt.... WTF happened??? That had to get REALLY hot. What circuit WAS in there??
Old Yesterday | 08:31 PM
ElkCon's Avatar
ElkCon
yea - which one did that?
Old Today | 02:00 PM
SteelVenom11
From what I know, it was previously a 20amp powering the dome lamp, courtesy lamp, stop lamp, reading lamp, glove box lamp, ignition switch lamp, time delay relay and lamps, and power door lock relay. Or at least that is what was listed connected to that fuse.
ElkCon (Today)
Old Today | 02:29 PM
Wonder which one smoked it.......
SteelVenom11 (Today)
Old Today | 06:52 PM
ElkCon's Avatar
ElkCon
it is one of those
Quick Reply: Fuse Box on 1990 Ram B350
