P0720 Output Speed Sensor - HELP!
Old Apr 5, 2026 | 03:59 PM
FelixAFM's Avatar
FelixAFM
Default P0720 Output Speed Sensor - HELP!
Hey guys - I have a 1999 Dakota with the 5.2. for a while now i’ve had an issue where i have a check engine for the output speed sensor, and it causes a very strange issue where my speedo goes all wacky and from a stop it will often just not shift into second and continue revving and shifting weird. I have to pull over and turn the truck off and turn it back on for it to work, often until i stop again and it does it again. I have replaced the sensor ages ago when it first started and it still persisted, and recently i figured it may be a broken wire as that circuit doesn’t ground to anything so i ran new wires to the sensor and it still didn’t work. I have also replaced the ecu and it still didn’t work. I’m kind of at a loss and would like to fix it so if anyone has any suggestions please help. Thank you!
Old Apr 5, 2026 | 04:08 PM
Which sensor did you replace? The one in the trans, or the one on top of the rear diff?
Old Apr 5, 2026 | 04:16 PM
FelixAFM's Avatar
FelixAFM
The one on the trans is the one i replaced
Old Apr 5, 2026 | 08:16 PM
OK, that's the right one according to the code. But, the speedo is driven off of the rear wheel speed sensor on the differential.....
Old Apr 5, 2026 | 08:19 PM
FelixAFM's Avatar
FelixAFM
yeah i’m really confused as to what’s going on. I guess could it be possible my rear wheel speed sensor is messing things up for me?
Old Apr 6, 2026 | 09:06 AM
I would suspect more than one problem. Replace the sensor on top of the diff, reset the PCM, see what happens.
Old Apr 7, 2026 | 09:16 PM
hidden1's Avatar
hidden1
Definitely put a OEM speed sensor on the differential! I had the same issue an that fixed the speedometer..Reset Abs too
Old Apr 18, 2026 | 10:57 AM
LIZZRD's Avatar
LIZZRD
I didn't put a OEM in the differential , I have brake and ABS lights on but speedo works fine... been a few years now.
