HID Special $60.00 Shipped for Dodgeforum members
#22
I went to the sylvania website and it says my pickup uses 9004 bulbs. Does that mean I can get http://www.hidextra.com/HID+Conversi...rsion+Kit.html and plug it all in and it will work?
#26
Hi, Yes please include your YEAR MAKE AND MODEL in the notes section when you order so we can double check if you need a relay.
Also , remember to input the coupon code fspecial-m so you get $15 off the online price, so your total for the bi-xenon is $90. THank you!
Michelle
Michelle
#28
Hi,
According to the picture that the customer sent me, we noticed that the issue why the bulb won't fit is only because the water seal is new and is thicker and harder than the older water seal from the older bulb, the base and bulb is exactly the same size but just the water seal, the picture shows that the bulb did go into the housing but could barely lock because
it needs to be pushed in a little harder and then use the holder to lock it.
We also recommended him to swap out the water seal on the bulb base to the old water seal so it's easier to lock if he didn't want to force the bulb into his housing and leave a small mark.
Let me know ifyou need anymore updates. Thanks!
Michelle
Michelle
