Notices
HID Special $60.00 Shipped for Dodgeforum members
Old 08-19-2011, 05:11 AM
bandroidx's Avatar
bandroidx
bandroidx is offline
could i not just plug both side harness's into the stock lights and each would get power from the relay and the hi/lo logic from each side rather than from the extra relay? So instead of the passenger side stock plug not being used, i would use it to get the hi/lo signal same as the driver side. ?
  #1022
Old 08-20-2011, 07:31 PM
bandroidx's Avatar
bandroidx
think i might try to install them tonight with the non bi-xenon harness and see what happens. hidextra, was this one sent to me as a mistake or does it work in some bixenon cases? If it was sent in mistake can you send me the correct one?
  #1023
Old 08-22-2011, 04:56 AM
bandroidx's Avatar
bandroidx
Ok i see now why i need a bixenon harness, hidextra can you please send me the correct one? My order number ends in xx251 .
Can i use the non-bi-xenon harness for the time being if i only use the low beams?
thansk
  #1024
Old 08-25-2011, 09:58 PM
bandroidx's Avatar
bandroidx
Ok, after speaking with hidsupport's phone support today, they explained that the new bi-xenon ballasts are can-bus safe and work fine without a relay harness. Further they said that the new bi-xenon kits work with a standard relay harness and dont require a bi-xenon relay harness. After inspecting the pigtail harness that comes with it, I see that they appear to be correct, the relay suplies the power and you plug the pig tail in to the passenger side headlight connector to just get the hi/lo signal. Either way I unforunately didnt get that far.
I started on the driver side, i hooked up the relay harness and connected it all properly and turned it on and i hear the relay just clicking. So then I am like **** I didnt have the fuse in the relay harness, so I put it in and now the lights are kicking on and off with the relay clicking. I am 95% sure this indicates a bad relay (not holding open) but I didnt have a spare, can you all confirm this would be probably just a bad relay?
So I hook it up directly to the head light for power (disabling the relay entirely) and it lit up perfectly. No strobing, no flicker, looked good. So it appears these new canbus safe digital ballasts are as good as they say. Still get light bulb out indicator but since I didnt use relays (i am 03) I expected this.
So I try the hi beam. This leads me to major problem #2
It starts making this clicking sound like it was hitting the top or bottom of the light. I quickly went back to low beam and it was fine. It appeared the bulb was notched and would only fit in one direction, but I guess not. I assume I put it in wrong but still dont see how it would hit anything if i did? Making it even more odd is that it appears I am low beam on when the low beams are on, (its pointing as the low beams did) but IDK. Any advice would be great. I thought also maybe its a bad unit as well and its not magnetically staying in place as it should and that is the clicking noise?
I am currently driving around with one hid and one halogen (wanted to get these issues worked out before ripping another headlight out), making me probably extra annoying lol, but it did give me a chance to compare the bulbs side by side, wow hid's make a world of difference! my 6k's are way more blue than i expected, i would probably go with 5k next time (wanted a crisp white with a tinge of blue)
  #1025
Old 09-12-2011, 03:13 PM
Sixfilthy's Avatar
Sixfilthy
Sixfilthy is offline
I have a 2007 charger RT. Will this kit work for me? I've had way too many flickering and lamp outs! I'm sick of dealing with my headlamps. Just NEED something that ACTUALLY works.
  #1026
Old 10-18-2011, 01:15 PM
hybridion's Avatar
hybridion
hybridion is offline
I tried to PM you, but your box was full. I was just wondering if the $60 shipped HID kit pricing is still in effect?
It's for a 2002 Dodge Ram 1500.
  #1027
Old 10-21-2011, 09:31 AM
BadHazard's Avatar
BadHazard
BadHazard is offline
I too am interested if the price is still $60.
Any feed back on the Rams?
  #1028
Old 10-21-2011, 03:17 PM
hidextra.com's Avatar
hidextra.com
hidextra.com is offline
Former Vendor
Hello,
Thank you for taking interest in our products.
Yes our kit is $59.99 (free shipping within USA)
and we have an on going 10% OFF, coupon code is: newcust
Please visit www.hidextra.com
Thank you!
HIDextra
  #1029
Old 10-26-2011, 06:52 PM
Teepler916's Avatar
Teepler916
Teepler916 is offline
Thinking about buying a set
2004
Dodge Ram
Laramie
So the capacitors are 10$ more ??
  #1030
Old 10-27-2011, 12:45 PM
hidextra.com
Former Vendor
Hello,
Thank you for taking interest in our products. Yes capacitors are $16. We have a 10% OFF promo, coupon code: newcust
And Our Halloween Sale will start tom, $20 OFF every $65 of purchase.
Thank you!
HIDextra
Quick Reply: HID Special $60.00 Shipped for Dodgeforum members
