Special Buy On Throttle Bodies From THE FASTMAN!
#101
RE: Special Buy On Throttle Bodies From THE FASTMAN!
Don't suppose you know if he makes or would do up a tb for a 90 'tona ES 2.5 turbo. *shrugs* I may be putting a DOHC Neon head on it, but then again, I might not, so if you could find out about throttle bodies for either, that woud be spiffy.
~Jon
~Jon
#103
#104
Jon, here is his response:
To sum it up I can modify about any TB. I do not know all the different makes out there so until I see it I do not always know what I can do. With TB’s I am not familiar with I need to see it or have it sent to me. Cores are readily available for most of the older stuff and I can normally get them very reasonably priced. The special TB’s take a backseat to my normal workload. It takes a bit to jig and fixture for some of this stuff. Most engines respond to a bigger TB. Gains I do not always know. How much bigger is common sense and experience. If customer is willing to work with me I will work with them.
So... LMK!
~Amanda
So... LMK!
~Amanda
#105
Hi Amanda,
I noticed in a earlier post that there is a throttle body for the new 3. V6 Magnum engines. I was wondering if you could let me know about how much it is and the Avg HP gains after installation. As of now the only thing I've done is put in a cold air intake. I plan on putting on an exhaust very soon.
Thank,
Matt
Thank,
Matt
