Oil pressure sender location.
Old 01-09-2012, 07:09 PM
89newbie's Avatar
89newbie
89newbie is offline
Default Oil pressure sender location.
O.K. so here it goes and I feel like an idiot. Last year changed out sender on 3.9 no problem. This year leaking oin down on bell housing same problem my mind told me. Picked up new sender annd started to do the job, daaaa, errrrrrrrr where is the sender? O.K. there is the EGR valve, and there is the Dist and where is the sender is it down in the vallet if the intake? Any one have a pic, Sure feel like an idiot on this one! THanks for any help guys. As far as , when we moved Mrs N. Packed it, its been harder to in findd than the sender...
Old 01-09-2012, 07:20 PM
hogback's Avatar
hogback
hogback is offline
it is on the left side of the distributor if your looking from the front of the engine
Old 01-09-2012, 08:29 PM
93dakotaman's Avatar
93dakotaman
93dakotaman is offline
The oil sending unit is located at the rear of intake on the left by the EGR valve
Old 01-10-2012, 08:54 AM
89newbie's Avatar
89newbie
89newbie is offline
Default Anybody got a pic???
This is weird. Im old but not blind, or maby I am.Yep thats where it is supposed to be. Guess what it aint! I have the EGR valve, all its plumbing and piping,then the Distributor. Checked for it in daylight went and bought an inspection mirror looked with lights last night, degunked the area, guess i will have to remove dist cap and wires and look very closely to see if it is broken off, but since I have pressure I dont think that is the case. Also the guy at autozone could find no tech pictures for the magnum.
Old 01-10-2012, 01:35 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
These will help.
Old 01-10-2012, 07:20 PM
89newbie's Avatar
89newbie
89newbie is offline
THanks guys so it must be smack dab up against the EGR across from the dist. Ill go pull the cap and wires, guess thats what happens when your running on the 66 year old side and dont wear cheaters. Oh well cleaned it all up hanging over the fender just had started the truck and the idle was up and down and i heard noise in the idle air motor that sounded like BB'S in there. ROFL I know old guys are supposed to drive new cars been there done that but for some reason I really like this old Dak! I have other plans for it but dont want to sound like im 16 so ill keep em to me until or till they drive the nails in the coffin
Old 01-10-2012, 07:21 PM
89newbie's Avatar
89newbie
89newbie is offline
Default where do you????
Originally Posted by Crazy4x4RT
These will help.
WHere do you get these pics?
Old 01-11-2012, 02:11 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The service manual that is downloadable in the FAQ.
Old 01-11-2012, 07:49 AM
89newbie's Avatar
89newbie
89newbie is offline
Thank's to all of you for the help. If it were a Chinese Moped, (50 to 300CC), or a Ford I would be home free but I bought a new Dakota in 2004 and that started it.
Old 01-11-2012, 08:00 AM
89newbie's Avatar
89newbie
89newbie is offline
How do we pull that up? I looked there, eclicked on 95 since it was closest and it took me to a site called rapidshare. What am I doing wrong.
Quick Reply: Oil pressure sender location.
