02 RT Tranny question
Old 05-27-2007, 08:28 PM
rcembry's Avatar
rcembry
rcembry is offline
Default 02 RT Tranny question
I pushed the throttle to the floor to speed through a yellow light and the tranny downshifted fine, but it quickly hit the rev limiter and would not shift up until a let off the throttle. Could a bad Throttle Posistion Sensor cause this? I know I need to replace do to a little rpm increase fluctuationwhile cruise is on.
Old 05-28-2007, 12:09 AM
Mean Green's Avatar
Mean Green
Mean Green is offline
Default RE: 02 RT Tranny question
It sounds like you may just need to adjust the shifter cable it needs to be a little loose.
Old 05-29-2007, 02:12 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Your kick down band maybe so far out of adjustment that the trans won't kick down or slips.
Old 05-29-2007, 05:09 AM
Mean Green's Avatar
Mean Green
Mine liked to downshift too easily after my tranny was rebuilt and it was too tight so it sounds like it may be too loose for you.
Old 05-29-2007, 04:31 PM
Kensai's Avatar
Kensai
Kensai is offline
Same problem with my tranny. After replacing both speed and output sensors, it seemed to help a little. But later I took my tranny in for its major scheduled maintenance (adjusting the tensioners, etc). Seems to help a little but overall, it can still slip on me during full throttle acceleration in drive mode. So just being safe, I now manually shift the tranny under full throttle so I do not get this slipperage during gear changes in drive mode.
Quick Reply: 02 RT Tranny question
