Lincoln Mark Viii electric fan install
Old 06-17-2008, 12:37 AM
bustabill's Avatar
bustabill
bustabill is offline
Default Lincoln Mark Viii electric fan install
Installed this a couple of weeks ago. Took some pics of what I did.
So far everything has been working great. We will see how it holds up to Arizona summer heat. We just hit 112 today.
Bill
The following users liked this post:
V8Cowboy (10-15-2021)
Old 06-17-2008, 10:19 PM
hemi head's Avatar
hemi head
hemi head is offline
Default RE: Lincoln Mark Viii electric fan install
That's neat. Nice 7 blade you got there....Is it a pusher or a puller ?
Let us know how it cools.
Old 06-18-2008, 11:17 AM
Mean Green's Avatar
Mean Green
Mean Green is offline
It's a puller hemi. I think I may have to look into redoing mine for a cleaner look. What did you pull your fan off of? I got mine off of a Mercury sable with the 3.8.
Old 06-19-2008, 04:17 PM
bustabill's Avatar
bustabill
Hemi, I have the Flexlite controller set to keep my temps around 180ish to 190ish. I have a 180 tstat installed.
Mean Green, I bought mine from ebay about $60 shipped to my door. It is from a Lincoln Mark Viii...not sure on what year.
Just a side note. I use to have a BeCool radiator installed. My BeCool had fitment issues and customer service was very lacking. It finally developed a leak 2.5-3 years later and I said screw it and dropped in a factory style radiator. After doing the efan conversion I wish I had done that first. It cost less and parts are readly available. The efan conversion probably cost me all of $200 versus around $500 for the BeCool.
Old 03-13-2010, 02:10 PM
02 4.7 Durango's Avatar
02 4.7 Durango
02 4.7 Durango is offline
Default efan
anyone have pictures of a 4.7 instal?
Old 05-12-2011, 03:16 AM
krkb's Avatar
krkb
krkb is offline
does the temp in arezona reach over 120 f ??
i want to install an electric fan but i'm afraid !!
cause i live in kuwait (middle-east)
temp here over 122 at summer !!
i'm really interested in your work ..
thanks
Old 05-12-2011, 07:22 AM
topdogcustoms's Avatar
topdogcustoms
topdogcustoms is offline
Arizona hits 110 to 115 in the summer it has been hotter then that here 128 is the record i wouldnt run just an e-fan
Old 05-12-2011, 02:47 PM
Brekar's Avatar
Brekar
Brekar is offline
Yeah Arizona is a great way to test your cooling system. My Eclipse just didn't like this Arizona heat, it always ran hot even with a complete over haul of the cooling system. I like that fan set up and will have to look into it if mine ever goes out. My Durango has the clutch fan set up (and I'm assuming that your's did at one time as well) currently, what is the advantage of the fan install that you did over one of those???
Later...
Brekar...
Old 05-15-2011, 08:11 AM
krkb's Avatar
krkb
krkb is offline
i was very lucky testerday ,i finally found used mark viii e-fan at junkyard
pictures of installing progress ( bustabill ) was very helpful to me
i installed it by myself
it's running will and keep my engine cool with a/c on traffic and the temp here in kuwait hit 110 today !!
but i'll wait for next month to see if it'll holds up or not ?!!
cause temp will hit over 122 !!
http://www10.0zz0.com/thumbs/2011/05.../675097977.jpg
http://www10.0zz0.com/2011/05/15/11/723864934.jpg
http://www10.0zz0.com/2011/05/15/11/148817046.jpg
Old 05-15-2011, 01:51 PM
02 4.7 Durango
Default install
very cool do you have any more pictures of the install
Quick Reply: Lincoln Mark Viii electric fan install
