loud squeak on bumps
Old 06-05-2006, 01:50 AM
hachacker5024's Avatar
hachacker5024
hachacker5024 is offline
Default loud squeak on bumps
about a week ago my 01 durango started making this loud squeak everytime you would hit a bump in the road sounds almost like metal on metal sometimes it will do it really bad and then other times it will barely do it at all and i cant figure out what it could be. BTW it is AWD- 4WD
Old 06-06-2006, 04:32 PM
Kensai's Avatar
Kensai
Kensai is offline
Default RE: loud squeak on bumps
Have your ball joints checked. Since your Durango is a 01 model, you may check to see if you did the ball joint recall. If the joints are fine, you may want to remove the rubber mounts on the anti-swaybar and relubricate them. Mine was getting louder and louder as humidty outside really drops. But on rainy days, no noise at all. Problaby because it got wet. I had my mechanic take the rubber mountings off and lubricated them and now no more sqeaking squaking noises.
Old 06-11-2006, 07:18 PM
yakkier's Avatar
yakkier
yakkier is offline
sounds like it's riding on bumpstops, i posted a thread in the general tech forum about this same thing..
Old 07-03-2006, 03:10 AM
BoSox's Avatar
BoSox
BoSox is offline
Check your sway arm bushing...I have a 2000 and they are dryrotted already
Old 10-25-2006, 04:33 PM
steelerguy's Avatar
steelerguy
steelerguy is offline
On my 1999 Durango it's the rear stabilizer bar bushings (front ones have never made noise). (Good picture in Haynes manual.) Have tried Silicon spray & WD40 but they only last a day or 2. Get motorcycle chain lube with Bee's Wax. Pull, clean & lube the bushings & the mounting area. Reinstall & torque to specs. You don't want these coming undone. Had to go to a motorcycle shop to find the lube.
Lasts 6 months to a year & then you have to do it again. Of course, if they are dryrotted, change the bushings but I'd still lube them with the chain lube as even new ones can make the noise. I think it's a design problem.
Old 10-26-2006, 07:50 AM
ILLXJ's Avatar
ILLXJ
ILLXJ is offline
I used dry graphite on mine. Going on 2 months & no squeaks. JIM.
Old 10-26-2006, 05:12 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
I used some stuff from permatex IIRC that was copper colored when I installed the rear spacers in my M3. never a squeek out of them. I'll see if I can find it when I get home.
Old 10-29-2006, 02:08 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Just replaced my front sway bar bushings last night and what a difference!
Old 04-16-2007, 11:08 AM
cstradling24's Avatar
cstradling24
cstradling24 is offline
Yeah I had this problem also and it was my sway bar bushings....
Old 05-15-2007, 02:05 AM
cstradling24
I also had the sway bar bushings problem...
Quick Reply: loud squeak on bumps
