I keep getting a p0171 code (lean bank 1) on my 96 Neon. I've changed the air filter and the O2 sensor and I've checked for vacuum leaks, but the CEL keeps coming back on, giving me the same code. It hesitates and surges a bit at cruising speeds and my gas mileage is terrible! What else could it be?
Karl918
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
fuel filter, coolant temp sensor, map sensor... a number of things really but of course if the other sensors are bad they should be throwing a code for them also... could be low fuel pressure either weak pump or weak regulator, could have a bad or weak injector(s), could have bad injector orings...
__________________
91 Chevy K1500 (current stock 305 to mildly built 350 swap in the works)
97 Olds minivan (wifes ride lol)
New Project 97 DOHC neon sport (Project daily driver :P)
It seems to have plenty of pick-up....wouldn't a weak fuel pump or clogged fuel filter or bad injector effect that? I did put some Lucus fuel injector cleaner in the tank...maybe that'll do it. But answer this....if I don't clear the code, will the symptoms continue?
When the car is idling, (and it idles fine by the way) the Fuel Trim is right where it is supposed to be, but as soon as I give it some gas the ST Trim quickly goes up to +24.2% and stays there.
I also checked the TPS, its fine. I replaced the pcv, and cleared the code, but soon the check engine light came back on. p0171. I even unplugged the MAP/IAT Sensor....no change in the readings. I was suprised the car started to be honest.
well all those things being bad would deff affect performance but if its only starting to go bad then its only going to be bad enough to limit your fuel flow so you get the code but not bad enough to hurt performance... if it was one of the sensor acting up you would have a code for that sensor or should... but it wouldn't hurt to get the fuel pressure checked which would tell you if the pump or the regulator was the problem... that would be a good place to start... as far as what to do from there... its hard to say...
__________________
Im still monkeying around with this. So Ive checked for vacuum leaks, replaced O2 Sensor, the MAP/IAT Sensor, the PCV valve, and the code still came back. So I got a ECU out of a '97 and the code went away but I got a new code 1491 (MIL 35) which is a problem with the radiator fan/s. They don't turn on. So I got another ECU, this time out of a 98.....got the same code! Spooky huh?
Is there something about the ECU's not being the same year as my 96? Can it be re-flashed?
By the way, when I pulled the original ECU, one of the connectors was full of oil! Appearently the Oil Sending Unit went bad and oil traveled up the wire to the ECU which I assume created the original p0171 code. I cleaned all the connections and replaced the Oil Sending Unit (which I think Chrysler calls Low Oil Pressure Sensor). It was a bit of a pain to replace because it didn't quite fit into the special socket made for it. I had to file the sides to get it to fit in the socket. I saw another at the junk yard with the same issue.
Thanks ScottyP. but I don't think its the intake gaskets because, just for giggles, I put the old ECU back in and I only got the original p0171 code....and not the 1491. Someone told me a little while ago that the (newer) ECU is probably fine but needs to be re-programmed for my car. Do you (or anyone) know whats involved and about what that costs?
