1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
to make it short and sweet...MY HEADLIGHTS AND TURN SIGNALS DONT WORK...they just randomly stopped working earlier. I replaced every fuse in the box thing under the dash..bulbs didnt look blown..what now?? need help with this as soon as POSSIBLE
Using a wiring diagram and meter/test light you need to check for voltages. Do you have 12 volts at both blades of fuse 5 when plugged in? Do the 4 way flashers work? Do the running/parking lights work? Are both high and low beams out?
This might help if you don't have them. Select pages of the wiring diagram. Anyone wants them as a PDF, send me a PM. I am not sure if there is much difference between the '82 and your '85.
thanks pumbu, ill follow those diagrams and see what i come up with. fine time to find out my volt tester is broken. no flashes/hazards work at all. the tail lights and yellow lights on the side come on when i pull out the lights toggle. the inside light above the back window is out as well but the dash lights work. i still havent found the high beams yet either. whats the "floor bright light dimmer switch"?
there should be a switch on the floor that controls the high and low beam. when it goes bad it can stop the headlights from work all together. it would still not expain why your other lights are not working.
should look like this
I'VE SEEN THAT THING!!! I pressed it with my foot a couple times trying to figure out what it was. but your right, that shouldnt stop the other lights from working. guess ill go and press it a couple more to see if anything different happens...this sucks..
