78 Dodge D150 318 dual ballast wiring diagram.
I Just wanted to post this 78 dodge 318 dual ballast wiring diagram for all to use...I highlighted all wires related to ECU, Ballast, coil, dist......Iv seen a few out there, but this one made it alot easier for me to trace down my "no start electrical issue"
Thanks Crazzywolfie, I had your diagram, But it was not near as detailed as the other one I found...Maybe same thing? But my little brain just couldn't wrap itself around that one...But seen the light with this other one I posted....Just thought someone (like myself) that might be strugling with it, might have better luck with this other diagram...I just couldn't figure it out with that diagram...until I seen this other one... Thanks again sir..
IN re: Diagram
I am wiring it top of four way ballast right side goes to + coil and then had a wire going to bal on fender starter relay, also have both bottom ballast prongs going to the 'hot' junction/intersecting link, top right going to ecu.
Orange Wire
There is one about 16 gauge wire coming from the column that plugs to a 3-way with one pin only coming out of the column, then it ran one to the fuse box. Just not sure where it went, it may be part of home built wiring that the previous owner did. Since I've owned it they never had an ignition fuse in the fuse slot for ignition. I ran the red wire to the junction outside the firewall. And the Orange to the starter relay. Not sure what wires go to either power bar on the fuse box. and what goes to Batt/ACC or IGN/acc in the fuse box. The hardwired ones are connected to BATT/ACC and IGN/ACC but I need to know the detachable ones.
Trending Topics
Parts
I run with 3 extra ballasts, an extra dist, ecu, starter relay, and volt reg. fuses, coil. Still can't get it to run.
