Crank no start 1991 LE 150
Old 01-31-2016, 08:54 PM
Rider99's Avatar
Rider99
Rider99 is offline
Default Crank no start 1991 LE 150
I have a 1991 le150 TBI manual transmission 4x4 .This problem has happened randomly for several months but while troubleshooting it would start working. Anyways now it seems to have broken for good.after parking it in the evening it would not start the next day crank no start. Looks like I have a moment of fire to coil and fuel pump but nothing while cranking. I have replaced the asd relay Where what do i need to try next. Thanks in advance anything and all will be greatly appreciated
Old 02-01-2016, 07:41 AM
Moparite's Avatar
Moparite
Moparite is offline
Do you hear the fuel pump prime the system when you first turn the key? Did you try pouring some gas down the tb?
Old 02-01-2016, 07:45 AM
Rider99's Avatar
Rider99
Rider99 is offline
Yes I do hear it prime when turn the key on.the pump does not run when cranking and I have not poured gas in the TB
Old 02-01-2016, 07:23 PM
Moparite's Avatar
Moparite
Moparite is offline
The pump does not stay running when you turn the key. It will remain off until the engine fires up once it primes the system. It may be your iac also, Do you hear it when you turn the key? Try giving it some throttle next time you start it.
Old 02-02-2016, 01:56 AM
Rider99's Avatar
Rider99
Rider99 is offline
I did pull the wire off of the coil and I am not getting fire. What is the iac. I do hear something in the area of the tb when I turn the key to the on position?
Old 02-02-2016, 07:30 AM
Moparite's Avatar
Moparite
Moparite is offline
iac-idle air control. Possibly a bad coil.
Old 02-02-2016, 11:05 AM
Rider99's Avatar
Rider99
Rider99 is offline
I could never get power to the coil while cranking and the asd tested good so I pulled the ecm off. Hope its right!
Old 02-12-2016, 02:38 PM
Rider99's Avatar
Rider99
Rider99 is offline
After replacing the ecm still the same thing a second of power to coil, pump primes when ignition turned on. When cranking no power to coil
Old 02-12-2016, 05:10 PM
newtjr's Avatar
newtjr
newtjr is offline
Good possibility that you have a bad distributor pick up (hall effect switch). NAPA part # is mp827. Pretty easy to replace. Google hall effect switch for testing. Hope this helps. newtjr
Old 02-13-2016, 06:43 AM
Rider99's Avatar
Rider99
Rider99 is offline
I went to town late yesterday and had to order the pick up I'll post back
Quick Reply: Crank no start 1991 LE 150
