body lift questions
body lift questions
1998 Dakota SLT 4x4 3.9L (extended cab)
Iv been looking into doing a 2 inch BL. I very mechanically inclined and I am not worried about the install. but before I start I wanted to know what else (if anything) would have to be extended in order to accommodate the extra 2 inches (steering shaft, fuel filler neck, wiring, break lines). I want to make sure I have all the necessary parts I need before I start to pull apart my Daily driver.
thanks in advance, Mike
I was looking at those kits and it seems they require you to weld two blocks L/R side of the bed to the frame and also cut the 4wd shifter in half and weld an extension on..
other wise i might consider doing it which I think I'd like but does not seem feasable if you have to cut and weld those.
I believe those blocks he's talking about are the overload spacers. You don't need them. Many people throw them away. I never installed them and 2 years down the road with multiple times of having over 1500 lbs in the bed and eveything is fine.
Electronic 4x4 switch doesn't need anything, but yes an extension is required for the floor shifter.
Oh and the only thing you need to extend is the steering shaft. You'll need to raise the front and rear bumpers using the brackets provided and cut your fan shroud.
Brake lines and fuel filler are fine for the 3.9 and 5.2. For the 4.7 I know that you need to extend a radiator hose and possible the fuel filler.
The fan shroud cutting you mean the ears it says to cut off? I dont think it mentioned anything esle but i would image that would reduce the effectiveness of the fan if its not pulling from the entire rad.
wish some people had some photos of this after finished with the 5.2L truck
on the extension i would be interested if we can find something that can just screw on or we could make our own shafts and do our own threading to accept a coupler and accept the shift ****.
Trending Topics
My guess (and it's only a guess) is that they're trying to manufacture the kit to a particular price point, and a short length of bar stock is much cheaper than a machined adapter/extension. But if you have decent fabrication skills, the screw-on extender should be reasonably easy to make.
