What's the Trick to R&R Plug #5 on the 3.9 ?
Old 10-21-2014, 08:08 AM
Katmandu's Avatar
Katmandu
Katmandu is offline
Question What's the Trick to R&R Plug #5 on the 3.9 ?
I just bought a 98 Dakota w/3.9 engine yesterday. I would like to change out the sparkplugs since it has 251k miles and an unknown repair history. It's running ok right now, but I'd feel better if it had fresh plugs etc.
Looking under the hood, it's clear the plug for #5 will be an issue since the brake booster sits so close.
So, what's the trick to removing and replacing that plug ?
TIA
Old 10-21-2014, 10:06 AM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
Bloody knuckles and a wobble socket.
I think I actually used a ton of combinations of wobble and 1/4 sockets to get at #5
Old 10-21-2014, 01:22 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Question
Right. What combination ?
Old 10-21-2014, 05:13 PM
magnethead's Avatar
magnethead
magnethead is offline
I use a socket, 3" extension, wobbly, 2" extension, then a ratchet with a flex head. Have to de-couple at the wobble adapter to get it in and out. Pull plug out and drop new one in using a stick magnet.
Old 10-21-2014, 06:14 PM
01SilverCC's Avatar
01SilverCC
01SilverCC is offline
I just put a 6" extension on my plug socket then drop the socket in the plug hole, put my stubby flex head ratchet on the extension and point the handle down and backwards below the brake booster. Then I just crack the plug loose, remove the ratchet and turn the plug out by hand. Then just use the socket and extension to insert the new plug, get it started and snug it down with the ratchet. Anti-seize on the new plug helps out a lot when it is time for the next tune-up too.
Jimmy
Old 10-21-2014, 07:59 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Great tips guys! Thanks!
Old 10-22-2014, 10:07 PM
lambs's Avatar
lambs
lambs is offline
I got tired of busting knuckles and bought a cheap air ratchet to remove the plugs, using the extensions and a universal joint type extension….is that what people referred to as a twisty? Not sure.
Not recommended that you tighten plugs that way….
Old 10-22-2014, 10:47 PM
Katmandu's Avatar
Katmandu
Katmandu is offline
Thumbs up
Good idea! I have one of those...haven't used it much but why not ?
Old 10-24-2014, 09:16 AM
cjantczak's Avatar
cjantczak
cjantczak is offline
i changed the plugs on my dakota before and your question about changing the #5 got me thinking how i did it??
i dont think i used wobbles or extensions just the spark plug socket on a ratchet and some cussing but im 100% sure. i would have to look and see.
Old 10-24-2014, 09:25 AM
cjantczak's Avatar
cjantczak
opps theres suppose to be a "not" after im and before 100%
Quick Reply: What's the Trick to R&R Plug #5 on the 3.9 ?
