2nd Gen Intrepid 1998 through 2004 Intrepids
code P0340 and P1684
Old 08-21-2006, 10:20 PM
egstandard's Avatar
egstandard
egstandard is offline
Default code P0340 and P1684
Can anyone tell me what these codes are? P0340 and P1684? Thanks, Kurt.
Old 08-22-2006, 03:04 PM
Dodgeramman's Avatar
Dodgeramman
Dodgeramman is offline
Default RE: code P0340 and P1684
P0340 camshaft Position Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
Here do yourself a favor and print this out.
Old 08-22-2006, 07:03 PM
egstandard's Avatar
egstandard
Thanks Scott.
Old 08-22-2006, 07:30 PM
Dodgeramman
Anytime thats what we are here for. But I'm shocked Nick didn't jump on this one..[&:]
Old 08-23-2006, 07:06 PM
egstandard's Avatar
egstandard
Swaped out the old sensor for a new one and all seems well. Car running fine and the check engine light is off. Now I've got to change the belts. Looks tight in there. Any tips?
Old 08-23-2006, 09:25 PM
Dodgeramman
Yeah go to a garage LOL. No seriously I don't know cuz I have not done mine yet. But if you don't get any help PM me and I will give you a site that will give some help.
Old 02-20-2007, 09:48 PM
Monstrddg's Avatar
Monstrddg
Monstrddg is offline
I just received this error code today.
Can anyone tell me where this sensor is located on an 01 w/2.7L and/or how much $$$ a new one is going to run me? OR point me in the right direction to find out on my own...
Old 02-24-2007, 07:43 PM
kurts2's Avatar
kurts2
kurts2 is offline
ORIGINAL: Monstrddg
Huh? This is the out of the 02 service manual:
OBTAINING DTC’S USING IGNITION KEY
(1) Cycle the ignition key On - Off - On - Off - On
within 5 seconds.
(2) The Odometer will show the P-code for the
DTC code number. Refer to the Emission section for
the DTC chart for a detailed explanation of the DTC
codes.
(3) If no DTC’s are present, the cluster will display
one of two texts: “P1684” and “done” or only “done”.
²
P1684 is only a status and indicates that the
PCM memory has been cleared within the last 50
ignition cycles and does not indicate a problem.
²
done indicates that NO DTCs are present and
the procedure is complete.
Where did you get this "P1684 Metering Oil Pump Position Sensor Circuit Malfunction" info?
Old 11-14-2008, 10:01 AM
goonies's Avatar
goonies
goonies is offline
Please remember to order the camshaft or crankshaft sensor from the "Dealer" and no place else????
Old 02-23-2009, 09:37 PM
TheOnlyWhitey's Avatar
TheOnlyWhitey
TheOnlyWhitey is offline
hello,
i saw this post and thought i would just add to it instead of creating a new thread.
i filled gas and went to start my car and it cranked but didnt start. i shut it off and tried again and fired up. Ive stopped and restarted it mulitple times since and seems to run fine. i got both codes of P0340 and P1684. My question is, I have 2 more days of work and a 80 mile drive to a shop to get it checked out. Is this gonna keep me from doing any of this??? is it going to be ok to drive it with these problems? any help is appreciated in advance! Thanks
Quick Reply: code P0340 and P1684
