DIY governor pressure sensor, solenoid install
Old 09-05-2012, 03:03 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Originally Posted by googlejuice
unable to remove pressure sensor!! what gives??
Might be nice if you added what year your truck is(all info about it actually) to your sig. They are NOT ALL the same. Some years require removal of the Gov body to remove the sensor.
  #102
Old 09-05-2012, 03:41 PM
googlejuice's Avatar
googlejuice
googlejuice is offline
New Member
97 ram 1500 4wd 5.9l. where is it and how do i remove it?
  #103
Old 10-28-2012, 11:57 PM
watrboi's Avatar
watrboi
watrboi is offline
This video gives great detail on replacing the described solenoids.
  #104
Old 02-04-2013, 03:58 PM
jonnyruckus's Avatar
jonnyruckus
jonnyruckus is offline
has anyone used the cascade heavy duty borg govenor pressure? did you notice any difference?
  #105
Old 02-04-2013, 04:00 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
it has become quite the common upgrade on the dodge trucks.
  #106
Old 02-04-2013, 05:42 PM
kawiultra99's Avatar
kawiultra99
kawiultra99 is offline
I just did mine over the weekend. Use the Borg Warner parts. Noticable difference. THe parts seem beefed up over the Mopar design
  #107
Old 04-03-2013, 04:20 PM
cbxsix's Avatar
cbxsix
cbxsix is offline
I'm a new member here thanks for having me, I have a 99 and 2001 Ram 1500's.
With that out of the way, I need to replace my GPS and solenoid, I called the trans shop I have used for 35 yrs and asked them to sell me the parts, he said just call Chrysler, they do not install aftermarket sensors or solenoids because of the failures they have had over the years. I know this tech personally and I don't think he is BSing me.
Is there a vendor that you guys are buying these parts from that you are confident in there parts reliability?
thanks.
Jeff
  #108
Old 04-03-2013, 04:29 PM
stewie01's Avatar
stewie01
stewie01 is offline
thanks.
Jeff
I think him telling you a dealer won't install aftermarket parts because of quality concerns is BS...
You can get the BorgWarner Governor Solenoid and Pressure Sensor on eBay for about $100.
  #109
Old 04-03-2013, 06:09 PM
cbxsix's Avatar
cbxsix
cbxsix is offline
Maybe you misunderstood me, they are an independent trans shop, the tech said they no longer install aftermarket solenoids and sensors because of past failures, they will only install OEM parts. I'm guessing they just pass the extra cost onto the customer and it cuts down on their return warranty work.
When I go to fleabay what is the best term to use in the search engine? these are for my 99 Dodge Ram 1500, 5.9, 4x4
Thanks for the quick reply by the way.
  #110
Old 04-03-2013, 06:23 PM
zman17's Avatar
zman17
zman17 is offline
Quick Reply: DIY governor pressure sensor, solenoid install
