Old 08-13-2015, 05:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
blend door actuator
Old 01-07-2011, 11:24 AM
offroadjosh's Avatar
offroadjosh
offroadjosh is offline
awesome thanks zman!!!i will try that today!
Old 01-12-2011, 11:53 AM
sungod's Avatar
sungod
sungod is offline
Any luck with it?
I messed around with mine last night and tried the steps. I couldn't get the **** to go past the mark and also didn't hear the door. I wonder how loud it should be. I assume the blend door is mechanical and moves by cable and not vacuum like the vents.
Old 01-12-2011, 12:03 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Originally Posted by sungod
Any luck with it?
That part of the system is not vacuum. You should here the door shut. If not, I'd say the lever is broke or the cable is stuck.
Umm, btw, what year is your truck? No info in your sig, you should know better by now,
Old 01-12-2011, 12:30 PM
sungod's Avatar
sungod
sungod is offline
Originally Posted by outdoortoys
The more I look at those videos, the more I am tempted to order. $35 shipped sounds a little pricy, but if it works then it would be worth it. If it were under $10, I would probably just order it an try.
Old 01-12-2011, 01:06 PM
zman17's Avatar
zman17
zman17 is offline
Depends on what year your truck is.
Old 01-12-2011, 01:35 PM
sungod's Avatar
sungod
sungod is offline
haa, I should know better! mine is a 98.
Old 01-12-2011, 02:30 PM
sungod's Avatar
sungod
sungod is offline
zman,
I just re read your post from the fsm. I think I confused myself by looking at the 01 FSM which is obviously different.
In the 98 is there a motor or does the cable do all the work of opening and closing the blend door? Can you post the section of the FSM that show the removal and installation of the cable? I assume to get at the door if there is a problem with the door that it requires removal of the dash?
Old 01-12-2011, 03:39 PM
zman17's Avatar
zman17
zman17 is offline
98 is still cable operated, no electric motor. And you are right, if the lever is broke, I know of no way to fix it, other than removing the HVAC unit.
Old 05-12-2013, 07:11 PM
Joliver's Avatar
Joliver
Joliver is offline
I have 2000 2500 & it has a motor that
holds blend Door open or closed. When I hit brake
Hard or bump door closes turning heat on
high. Had to take motor off & spen by hand
& can feel shaft not grabbing door. Anyone
now how to get it apart
Old 05-12-2013, 07:26 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Two screws and an electrical connector to take the motor off. (one is cleverly hidden close to the firewall....) If the door has separated from the axle it pivots on, you need to pull the heater box, which means the dash needs to be removed. (good time to change heater, and evaporator cores....)
if the motor simply doesnt grip the shaft, do a search on "heater treater".
Quick Reply: blend door actuator
