transmission cooler line quick connect HELP
i replaced my lower transmission line and radiator and i cant get the line to connect back into the quick connect on the radiator. i have a 97 ram 1500 5.2l v8 4wd . is there a special tool i can get or something ? i just cant seem to push it in. please help.
thanks
thanks
I know this is an old thread... but I can't find many on this. My brother (sold the truck to him 6 months ago) just replaced the radiator today with a spectra 2291. Everything bolted up great, with the exception of the lower quick disconnect. I said the same thing that he just needed to make sure the connector was straight, and push a little harder. Well... I just drove 3 hours one way to see for myself, and it literally will not go on. I can clip the line on the old radiator no problem, and remove... over and over. The lower stems look identical (stock vs spectra), however when I run my hand across it I can feel that the new one is a hair wider at the entrance. I tapped the connector in place... but can't be 100% sure that it clipped correctly. Didn't really have a choice, and did what I had to do. No leaks. That said, I want to correct it properly in a few weeks when he will be around.
Looked in dodge parts manual for the bottom fitting / stem. I can see the stem in the picture, but... no part number. Just have numbers for radiators with fittings.
Looked on spectra's website for a replacement stem piece, but did not see anything. May have to give a call.
Has anyone ever found a part number for that piece by itself.
Trending Topics
The thing that scares me is... I would have to cut the new radiator stem because I can't get that quick disconnect back off at this point. If I try to put the stock one back on, there is no going back. ... might have to borrow a radiator to experiment before I cut anything On the upside, at least I just need to replace the quick disconnect check valve delete line. Shouldn't be to bad of a fix if the flare fittings will swap.
I know this is an old thread, but it was the only one that popped up in a desperate search late last night. LOL
anyway, same problem I could not get those things to push in all the way AT ALL..
Finally I pulled the spring clip out of the fitting and made sure the hose would push in far enough to the Radiator. It did, so I now focused on the spring clip. What a pain in the A$$ this thing by itself was to push on.
So I tried a different approach.
I put the spring clip on the pipe, used the disconnect tool to snap it over the barb. then took the quick connect fitting with the center bushing and o-ring still in place, and pushed it over the pipe and spring clip.
heard it click as the quick coupling snapped over the spring clip.
As far as I can tell when the clip is spreading apart to make it over the barb, the center ring deforms and digs into the pipe making it very hard to move.
I don't know if the OEM parts are like this or just aftermarket ones.
These were dorman hoses from rock auto.
anyway just posting this to help someone searching with the same problem.
Just make sure the whole spring clip has been snapped under the lip of the quick connect.
Spring clip only on pipe.
Bushing and o-ring only in quick connect.
