vacuum leak.. wheres this supposed to go?
are you talking bout that "emissions sticker?" you mention before thats under the hood?
I know that vacuum lines go to a switch for your transfer case. When ever i go to put my truck in four wheel the light on the dash doesnt show ive even tryed to turn the wheel left to right because i heard this makes it easier to engage. The only thing that makes the light illuminate is putting my truck in reverse for just an inch or two. Is this normal or all apart of my vacuum leak?
O.k so at lunch today i took a closer indebt look under the hood and first off is this the diagram you are refering to?
second the 3rd picture up top with the broken hose is on the passanger side (incase noone noticed the trans dip stick) now while at lunch i found this next picture. it looks to me as if there should be a hose coming from there but theres not. this hose is on the driver side by the distributer its in the same coduit tubing as as a white electrical cable that goes from the passenger side of the throttle body to the back side of the engine and down under the truck by the distributer.. should there be a hose connecting these two broken pcs??? or is there a 3rd brake some where
Trending Topics
I looked under the battery tray everything seems in tact... if i remember from what i heard thats where the cruise control vacuum line is... I cant check to see if the cruise control is working because i im in the belief that i need a new clocck spring (my horn doesnt work either)
so these next two pics that im posting my question is are these two supposed to be connected???
