question on rings
Old 05-14-2013, 05:03 AM
t's dodge's Avatar
t's dodge
t's dodge is offline
Default question on rings
okay 1999 Dodge Ram 1500 5.2 I took the heads off. took them to a machine shop and they check out fine. so I pulled the Pistons and the Rings are shot I thought about just getting new pistons and new rings and of course everything associated with that and having the block honed by the machine shop does that sound like a good idea or should I just save my money and do something else? the original problem was cylinder number 1 and number 3 had about 45psi compression the rest of the cylinders check out at about 150psiI was getting gas in the oil and a really crappy idle i was missing on those two cylinders if I disconnected those two injectors the truck would actually hold Idle if I left them pluged in the truck would die and was only able 2 crank at Wot.
Old 05-14-2013, 06:21 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
You could find a Junk yard motor if you don't wanna rebuild it
If you rebuild it right it'll last a lllooooonnnnggggg time
Old 05-14-2013, 06:35 AM
t's dodge's Avatar
t's dodge
I do want to rebuild it funds are just really tight right now and I really need my truck I thought about a junkyard engine all I could find were im at is 100,000 mile motors for 650 and up I can do what im talking about for less than half that my question is would it work?
Old 05-14-2013, 11:37 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
T's,
Your going to want to have your heads checked for any cracked. I didn't even bother with having mine checked I just bought some aftermarket heads and went with the larger valves while I was at it. I wouldn't go for the 2.20 valves on a 5.2 as they are just too much for a stock engine.
If you can swing it do a poor man's rebuild. Replace only the parts that NEED to be replaced. Is can be done for pretty cheap if your able to use all standard size bearings and stuff. That is how my engine rebuild started but I have gone past that now.
Old 05-14-2013, 01:41 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Check the bores, if bores are still within spec, put on new rings, and call it a day. (or, toss in bearings as well.... )
Old 05-14-2013, 05:34 PM
t's dodge's Avatar
t's dodge
Ok I went to auto parts warehouse and got new rings pistons and bearings. I am going to have the machine shop rebuild the heads they called and everything checked out ok. got the ebay planum plate ordered and all new gaskets and oil pump while im in there. already has a new timing chain less than1000 miles. I just feel like im missing something. Thanks guys for the info I was afraid I couldnt do it this way
Old 05-14-2013, 10:16 PM
spun360's Avatar
spun360
spun360 is offline
i would score the bores real good. at least to help seat the new rings.
what type did you go with? moly or cast rings?
Old 05-15-2013, 12:14 AM
t's dodge's Avatar
t's dodge
Moly rings and I will score the cylindes thanks for reminding me.
Quick Reply: question on rings
