01 1500 check gauges light coming on
Old 04-22-2014, 03:26 PM
cgsod's Avatar
cgsod
cgsod is offline
Default 01 1500 check gauges light coming on
Been having trouble with my check gauges light coming on then the volt meter stops working and every so often the speedometer will stick. Any ideas?
Old 04-23-2014, 12:54 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
Welcome to DF.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
I will move you to the correct section.
Old 04-23-2014, 12:27 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
See if it is the gauge, or if you are actually having charging issues.
Old 04-23-2014, 02:25 PM
jkeaton is offline
Check your battery and connections.
Old 04-23-2014, 03:09 PM
ThisIsChallenging's Avatar
ThisIsChallenging
ThisIsChallenging is offline
Any update? Having a similar issue.
Old 04-24-2014, 01:55 AM
cgsod's Avatar
cgsod
cgsod is offline
Battery connections are good, new battery and terminals and it's been doing it for awhile now and the battery hasn't died so I'm pretty sure charging system is good
Old 04-24-2014, 11:04 AM
May be as simply as a bad connection at the back of the cluster.
What is your volt gauge saying when the lite comes on?
Quick Reply: 01 1500 check gauges light coming on
