5.9l Not eaching Engine Temp.
opps hit the button while I was editing the title. It's NOT REACHING the 195 temp.
My '99 1500 4x4, 5.9l auto. 86k miles. I installed a Hughes FI AirGap intake last fall and it runs like a raped ape.
BUT the truck has been running cooler and cooler and MPG falling all summer like the thermostat is stuck open, so I changed the thermostat with the 195 deg and the temp sensors, BUT its still running cold maxes out at 180, I am driving up to my cabin tomorrow see if it gets any warmer.
Would a bad clutch fan (stuck on) keep the engine from getting to the 195 deg.? Or is there some secret I never heard of.
And now that winter is here I gotta get the heat working before the deep freeze hits. My heat has been minimal, but today after messing with the heat ****, I got the heat to start coming up. Went from its 95 deg to 140+ deg after messing around with it. I think the Heater control panel needs to be replaced.
Best place to get a new one?
Trending Topics
Well replaced the Sensor, But I had it backwards last two sensors were BWD.
So I changed it up and went with the duralast. Showing a little warmer 187deg at idle.
Definitely up on the factory gauge.
After messing with the heater lines had some sludge in the system. Time for a full system flush.
Renting so don't have access to a decent water source.
One would think finding someplace to do an true coolant flush & clean wouldn't be such a task.
All the local joints just drain the radiator fill with distilled water run it, drain and fill with antifreeze. They call it a flush & clean, just a crappy flush if you ask me.
The only place I can find to do a real clean and flush is about 40 minuets north of me through a bunch of road construction (that by the way NEVER ends here in Milwaukee)
