1997 Ram Transfer Case Noise
Hi I just purchase a 1997 Ram 1500, knowing full well, there was an issue with the 4WD. The seller told me it "grinded" going into 4WD so he didn't mess with it. I test drove it for a half hour, and seemed good. Now I hear a rattle and it appears to be coming from the transfer case, only when moving at low speeds. For all I know the rattle could have been there all along, I only noticed it while at a drive through and it was echoing off the building. I intended on having the 4WD issue fixed, etc over the course of the summer, but this rattle concerns me. I have a friend that works at a reputable salvage yard, and can get a transfer case for about 100.00 or so. What are your thoughts...should I buy a rebuild kit and attempt to rebuild it, or should I buy one from a salvage yard and do that. I don't have bearing presses, etc for the rebuild, so that may be difficult. Also Any idea what may be causing that Rattle noise? The truck is really clean outside of that, so I would like to get it fixed ASAP. Thanks!
Yeah I know it sounds odd. The only way to pin point it is to climb under while it is running in gear. We did that, and it sounds like it is coming out of the transfer case and the sound is amplified all the way down the driveshaft. The u-Joints feel good. I was thinking with the grinding of the 4WD that it is probably in the transfer case like it sounds. It just sounds like something is broken off or loose in there and as something is spinning its going around and around..
Trending Topics
