Will my axles really get destroyed?
Hey guys I have a 2001 Ram 1500 Sport Off Road edition. I previously had a post about 4" coil spacers and AAL and was talked out of it which is probably for the better. I will be doing a 3" PA BL as well as possibly (POSSIBLY) 2" coil spacers, and AAL. I currently have a 5" RC suspension lift. I would like to run 38-40's if possible. I dont do any off roading and this is my daily driver (for now but will be getting a work truck soon.) My question is if im doing street only driving would I be able to run the 38-40's without issues on my 1/2 ton axles or do I NEED to upgrade?
Just do it and report back. lol
You really haven't searched around much. In any event at least you say it's a street pounder, which doesn't actually mean it's all gentle. It's all dependent on how you drive it.
To put in perspective a bit...in order to avoid getting up to speed at the rate of 5 mph, the axles need to be regeared to at least 5.13 for those size tire range. That's also to avert damage to the transmission, which presuming you have an automatic.
The 5" lift plus other stuff you mention can fit it with likelihood to need some trimming on fenders.
oh...Chrysler 9.25" gear ratio tops out at 4.88.....if you can find them.
It doesn`t matter what size tires you run, but if you don`t have the right gearing for them, you are going know were fast, and you can and will do major damage to other parts if you try. I would recommend that you do a lot more searching and reading, so you can learn what needs to be done and why.
I think I'm gonna go with the 38's or at most 39's. this will be my daily driver for about 4 more months till I get my work truck for everyday driving. I wouldn't mind upgrading my gears to like a 5.13 or a little higher, I just can't figure out how to know which ones I would need/where to get them. if anybody has any recommendations it would be much appreciated. I've been looking all over but I'm still very new to this so I'm still kinda clueless
Biggest you can go on the half-ton axles is 4.88. Finding the 4.88 for the rear is getting to be rather difficult.... Randy's Ring and Pinion *might* sell them... but, don't hold your breath.
But, in all reality, for 39" tires, 4.56 will have your engine running slightly faster for a given road speed. (about 230 RPM higher in 3rd gear @65mph.)
And, all THAT said..... try not to act surprised when NOTHING in your front suspension/steering lasts very long. Those big tires are HEAVY, and the D44 just wasn't designed to deal with that kind of weight on a big heavy truck. (on a jeep is a different story, several thousand pounds lighter.....)
Trending Topics
I had my truck in the shop previously and the mechanic said my axle seals were shot in the front so they would need to be done. He said in order to do that he has to open up the differential and whatever else. I figured when getting the axle seal done I could also try getting the gears done. I will probably only go to the 4.88 (If I can find it) for now, so I don't have to swap for a Dana 60. Obviously I would need the ring and pinion as well as the axle seals. What else should be replaced if i'm going to have it all opened up? I will have to look around for a little while to find the front and rear parts as well as finding a mechanic who can do that as well and do it right.
Any thoughts on this for the front end? Price wise, will it work, etc?
http://www.offroadpowerproducts.com/...FUE8gQodbWUATA
Here is another one that is apparently front and rear
http://www.4wd.com/Jeep-Drivetrain-J...FWwV7AodFTgAOA
Although they all say jeep? Does that not matter because its still the same axle or does it make a difference
