front end noise
front end noise
I have a 94 1500 5.9L auto and I just got the truck and I'm still finding all the little things wrong. When I make a hard turn at low speeds. I can hear a intermittent loud sqeak in what sounds like the driver side front tire. It doesn't sound like a bearing. I've never had universals in my front axels. So I'm wondering the symptoms when they start to go bad. I climbed under neither and didn't see or feel anything loose anywhere in the front end. I don't want to tear it apart until I can pinpoint the problem. also I want to add there is no lift kit and I'm running stock rims on 265 75 16s
Sounds like 4wd since he mentions "universals" in the front axle. When you mean hard turn, is the wheel at full lock? If not, yes probably the u-joints. Check the caps for orange rust. Usually the cap will dry out and rust solid creating the squeak. Could also be hubs so jack it up and rock the wheel from 12 to 6 for any play. If not, could be power steering pump whining.... But these trucks love to eat u-joints and hubs so my bet is there.
