wheel shakes bad
wheel shakes bad
Ok so I have a bad shake when driving down the road.I went to jack it up&the wheel has play in it if I try to wiggle left to right,&if I try 2 spin the tire from left to right it makes noise .
The tire also seems to have a bubble.Could that came from the wheel being loose? Also when I pull the wheel what should I look 4? A buddy said it's probably because he didn't use an impact when he put the tire back on after he did the brakes a couple months ago because with these wheels an impact has to be used is that true?
They need to be torqued to the proper spec, an impact wrench is generally much higher torque, and tends to distort things...... (150 ft/lbs for your truck, and even my wimpy impact does 225.....)
Bubble on the tire will give you a shake. So will bad wheel bearings, and loose steering parts. Generally, bubbles on tires is from belt separation, which is usually from an impact with something.... even a pothole.
Trending Topics
Really hard to tell from that video and your description, but the yoke looked pretty rusty on that axle shaft, which usually means the u-joint is shot. Is there any play between the inner and outer shafts at that joint?
That would cause a clank as you're rolling slowly.
The bubble in the tire, is that on the sidewall or the tread? If on the tread, it'll definitely make the wheel shake.
And if there's play in the bearing, the ball joints, or the tie rod ends, it can cause other shaking.
Thanks, the bubble is on the top of the tread about like if u were 2 set your hand ontop above the sidewall.I wrote another post I put some 22 37s on there & didn't tighten down enough I guess but that side that tire flew off.Gonna try 2 tighten hub nut if theres still play but on the 300 hub...ouch!
ok, did that wheel come loose? Try putting 2 lugnuts on without the wheel, tighten them again and try to turn it and see what it sound like. I'm thinking the rotor is only tight when the lugnuts are torqued, and that will explain the noise and movement in the video. Also if you have driven with that whells lugnuts loose, you could have made the holes in the rotor larger and possibly stressed the heads of the lugnuts everytime you hit the breaks. I would inspect the rotor and lugnuts, plus take a look at your wheel bearing while doing all that. And the rust power on the ujoint says replace it or break it
