AC turns hot
AC turns hot
When the AC is on and I get on the brakes hard it
turns hot. If I turn the switch to off for about 5 seconds
then back to AC it immediately blows cold. I've checked
the vacuum check valves and they are fine. The blend
door is electric so this is where I'm stumped.
Any ideas.
Thanks for any help.
Any ideas.
SoCal desert? Argh, you WANT your a/c to work right. Wonder if the temp door is flopping around...... Drop the little electric motor, and look at the coupler between the motor, and the axle for the blend door, bet its cracked.....
Heatertreater.net.
Heatertreater.net.
Thanks man. I was thinking about that, I'm sure I have that issue as
when I move the temp control it's either hot or cold, no in between.
It just doesn't make sense that a quick off and on with the control ***
switches it back. I really had not wanted to try to get to that 3rd screw.
I'll give it a shot and let everyone know.
Heatertreater.net.
Heatertreater.net.
Trending Topics
Not the heater core. That thing hangs onto its air pocket like a miser hangs on to his last coin.
