Wideband Finally Installed
Old 04-24-2009, 07:16 PM
mikset's Avatar
mikset
mikset is offline
Default Wideband Finally Installed
Finally got the Wideband Commander installed a couple weeks ago.
Seems like some of you guys were asking about a pillar pod for our trucks. In case someone else wants to try it, I thought I'd post this to show how I did mine. I used the universal single pillar pod from Glowshift Direct. Used a heat gun to form it, very slowly or you'll waste the pod like I did the first one. Plastic adhesive to stick it to the pillar post. Make sure you use a plastic adhesive that works on PP plastic, I used Loctite plastic adhesive. I then took it to a body shop and they blended it in with some kind of plastic putty and sanded it ($40.00). I textured and painted it. I used Sem texture coating to texture it and SpectraMatch trim paint from DieselManor to paint it. I used Mopar Natural beige, part #SM-D128AA. Came out pretty good I think. The texture is not an exact match to the other side but really not noticeable unless you're looking for it.
The WBC works exactly as advertised and the install is a snap as long as you're careful and follow the directions.
http://i216.photobucket.com/albums/c...t/IMG_3507.jpg
http://i216.photobucket.com/albums/c...t/IMG_3509.jpg
Old 04-24-2009, 07:48 PM
baracis's Avatar
baracis
baracis is offline
Looks great!
Old 04-24-2009, 08:03 PM
mikset's Avatar
mikset
mikset is offline
Eric, I got the Dynojet Wideband Commander from Air Ram.
I'm also doing some research on a turbo, l assume you're looking at an STS? PLease post up any info you come across!
Seeing how it's a universal kit, my biggest concern is the install cost.
BTW you can get an SCT "canned" tune without a wideband but if you go with a turbo I think a custom tune would be a necessity.
Old 04-25-2009, 09:12 PM
Blown287's Avatar
Blown287
Blown287 is offline
Mikset, your gauges look awesome. For you guys in the hunt of boost, good luck. I can tell you boost rocks.
Old 04-25-2009, 10:19 PM
Altair's Avatar
Altair
Altair is offline
Dak attack!
Hoping to get some myself in a few years. Can't afford to hunt boost just yet so I gotta hunt the money first
Old 04-25-2009, 11:31 PM
mikset's Avatar
mikset
mikset is offline
Thanks man. Stall converter next then either cam or boost. I'm hoping boost but kind of depends on the $$.
Old 04-27-2009, 10:56 AM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
The RAM Administrator
Dodge Forum Administrator
Nice install man! Did you use the same pods for the steering wheel cover? or whered you find that?
Old 04-28-2009, 06:56 PM
mikset's Avatar
mikset
mikset is offline
Steering column pod is for a 05 Ram but the 05-07 Daks have the exact same steering column so it works.
Quick Reply: Wideband Finally Installed
