Woodgrain bezel no more!
Old 02-23-2010, 08:36 PM
lmrjason's Avatar
lmrjason
lmrjason is offline
Default Woodgrain bezel no more!
So in the spirit of getting a bunch of stuff done today I decided to go ahead and order a silver bezel from moparpartsamerica. It was 131.00 plus shipping.
I ordered it and a couple hours later i got an email back from them. they said chrysler changed the bezels somehow and now the price is 220 dollars. Screw that. So i went to autozone and bought some spray paint and some sand paper. Pics will up tonight!
Old 02-23-2010, 08:48 PM
lmrjason's Avatar
lmrjason
lmrjason is offline
cooking in the oven
Old 02-23-2010, 09:29 PM
jnd03's Avatar
jnd03
jnd03 is offline
nice what grade of sand paper did you use? post some pics of it on I would love to do this to my truck
Old 02-23-2010, 09:46 PM
lmrjason's Avatar
lmrjason
lmrjason is offline
I dont know how this is going to hold up so in the long run but it looks really good right now. This is what i did.
From start to finish it took me about 2 1/2 hours.
I used duplicolor metalcast ground coat for the color and duplicolor acrylic enamel over the paint. I removed the bezel from truck and brought inside. Removed the vents, ac controls, airbag and 4x4 switch. I taped off everything else that was black. I used 600 grit sandpaper all over the woodgrain. I cleaned it up really good. I put on first coat and then put in oven on lowest setting for about 5 min. Took out and repeat. I used 4-5 coats. Repeat same process with enamel. I did 4-5 coats of enamel but it would probably be a little more glossy with a few more coats. Very light wet sand with 1000 grit and clean. Very light wet sand with 2000 grit and clean. Put everything back together and this is what you have...
Old 02-23-2010, 10:01 PM
jnd03's Avatar
jnd03
jnd03 is offline
so you would spray and then put in oven for 5 mins each coat? then at the end you used wet sandpaper after putting last coat of enamel?
Old 02-23-2010, 10:11 PM
lmrjason's Avatar
lmrjason
lmrjason is offline
yeah...i'm sure somebody else will chime in and tell you a better way to do it but i'm really impatient so thats what i did. So spray...oven on low for 5 min...let cool for a couple of minutes and repeat. The wet sand took off more enamel than i thought it would so thats why i said to use more than 4-5 coats of enamel. And be careful unhooking all the wires...I dont think that wire fasteners are dodge's forte. I broke the clip on the passenger airbag light at the top. Oh well...thats what glue is for.
Old 02-23-2010, 10:18 PM
Blown287's Avatar
Blown287
Blown287 is offline
That looks really good.
Old 02-23-2010, 10:29 PM
lmrjason's Avatar
lmrjason
lmrjason is offline
More importantly, it was also really cheap.
I forgot to say something...before you paint, heat the spray paint cans up by putting them in a bucket of hot water...the higher temperatures cause the paint particles to come out finer and makes a more even coat.
Old 02-24-2010, 08:31 AM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
The RAM Administrator
Dodge Forum Administrator
Awesome work man, I think this is DIY worthy! It looks great!
Old 02-28-2010, 12:08 AM
bryan1275's Avatar
bryan1275
bryan1275 is offline
Talking This worked great!!!!
I followed these instructions and it worked great. But I used Rustoleum High Performance Wheel paint.
Quick Reply: Woodgrain bezel no more!
