View Poll Results: What temp thermostat you runnin!
Stock
144
68.57%
180 t-stat
60
28.57%
160 t-stat
4
1.90%
Other(post in reply)
2
0.95%
Voters: 210. You may not vote on this poll
Thermostats
Old 02-19-2009, 12:57 AM
hemiyellow's Avatar
hemiyellow
hemiyellow is offline
DC Insider
Default Thermostats
You still livin with the stocker or you replace with one to keep cooled off? What brand you go with? Like it or hate it? Let us know here.
We all know that thermostats are extremely important to the life of an engine. Installing a low temp t-stat and help improve the life of the engine by allowing the engine to run at a cooler temp.
Old 02-19-2009, 01:01 AM
hemiyellow's Avatar
hemiyellow
DC Insider
still runnin the stocker for now....had a Jet 180 in my lowered ram tho, loved it...kept er nice and cool
Old 02-19-2009, 01:43 AM
tafet's Avatar
tafet
tafet is offline
I'm running a JETT 180 in my RAM. I like it.
Old 02-19-2009, 09:13 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Jet 180*
Old 02-19-2009, 08:48 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
Stock now, but a 180 tstat is on the list of things to do.
Old 03-15-2009, 04:29 PM
StinkyD's Avatar
StinkyD
StinkyD is offline
do they make 180* for the 4.7L or just you hemi guys
Old 03-16-2009, 12:48 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
That myth is untrue.
The engines are designed for certain clearances that are achieved between 195 and 200 degrees. They are also more efficient at this temp. Running cooler than that causes parts to be moving at the improper dimension.
Worked fine in older engines that would barely go 100K without a rebuild. Today's tighter engines can go well over 200K with proper routine maint.
This is also why today's engines use 5w20 oil vs 10w40 like in the 70's.
Old 04-06-2009, 07:37 AM
HammerZ71's Avatar
HammerZ71
To an extent, I agree with you. I'd not recommend a cooler thermostat in a stock truck. But a big advantage to the cooler thermostat is that it causes the PCM to richen the A/F ratio.
Other mods like a tuner, which advances the timing, causing a lean mix, and better "breathing" mods such as CAI and Headers all work to lean you out. In these instances, a cooler thermostat is a very inexpensive alternative to a piggyback A/F controller or a custom tune to get your A/F back in spec...
Old 04-06-2009, 09:52 PM
davb673's Avatar
davb673
davb673 is offline
Good points Hammer. I've kept my stock tstat mainly due to those reasons. I don't have a tuner, and I don't hear my engine ping, so I'll stick with it... For those looking for mpgs, a 180 tstat will not help.
Old 04-23-2009, 10:52 PM
metallica77505's Avatar
metallica77505
metallica77505 is offline
JET Makes a 180 degree thermostat for my 3.7l, im sure they have one for a 4.7l, check them out.
Quick Reply: Thermostats
