Spark plug HELP PLEASE!!! 2007 dodge ram 1500
Old 04-15-2010, 02:40 PM
dmiller369's Avatar
dmiller369
dmiller369 is offline
Default Spark plug HELP PLEASE!!! 2007 dodge ram 1500
so the dealership wanted 440.00 to change my spark plugs...im thinking yeah right.
I went out bought all 16 spark plugs for 68.00. i guess i didnt realize what i was gettin myself into considering there not the standard wires.
i got on cyl done.(two plugs) and now i stuck.
anytips on how to get in there and remove the plugs?
any help would be awsome..thanks.
Old 04-15-2010, 02:56 PM
04HemiGreg's Avatar
04HemiGreg
04HemiGreg is offline
Tons of posts to search for here. Have the right tools and plenty of patience. A u-joint and different size extensions for your socket wrench is a big help.
Old 04-15-2010, 02:57 PM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
Most guys only use an extension, ratchet, universal joint, and some guys use a bit of hose to put over the plug to get them in and started when replacing. I'm sure other guys will come on to help. From what they say, it is a PITA. Good luck
Old 04-15-2010, 02:58 PM
ramhunter9's Avatar
ramhunter9
ramhunter9 is offline
search the threads , i posted what tools you need and the guys gave tips and info .
Old 04-15-2010, 03:03 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
It's amazing the price differences between dealerships. My neighbor with an '06 Ram Hemi 4x2 just got it done while I was in Georgia and he was pissing and moaning about them charging him $185 to do it!
But yeah, do a quick search, there a plethora of threads and I'm sure a DIY on it.
Most are easy enough to get to, two of them are a bigger bi*ch than my ex wife however. It's a good 2 1/2 - 3 hour job and I personally don't know how anybody could do it without the piece of hose...
Old 04-15-2010, 03:39 PM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
I did it fine without the hose. I had a short and long spark plug socket that I alternated between though.
Old 04-15-2010, 03:49 PM
nateroach's Avatar
nateroach
nateroach is offline
I am coming up on this pretty soon too. I ordered a set of these to hopefully make things a little easier
These have a magnet inside to hold the plug, and the extensions are attached, so they can't pop off while trying to extract the old plug. those coupled with a u joint, and a swivel head ratchet and I think that I should be pretty well set. I just have to prepare myself for the ~4 hours it is going to take.
nateroach
Old 04-15-2010, 03:53 PM
bigmac18's Avatar
bigmac18
bigmac18 is offline
I found it MUCH easier to remove the front tires and wheel well liners, and get at them from underneath. Good Luck!
Old 04-15-2010, 04:51 PM
haulinhemi06's Avatar
haulinhemi06
haulinhemi06 is offline
if you have a jack and the proper tools, save yourself 400 bucks. dont waste it at the stealership. they charge way too much for labor.
you could buy a ton of stuff for $440.
Old 04-15-2010, 05:29 PM
Mega-Hemi's Avatar
Mega-Hemi
Mega-Hemi is offline
Damn, I think I paid about $30 for all 16 of mine.
And unless I'm mistaken, with a 2007 you shouldn't have any wires, which actually saves time.
Quick Reply: Spark plug HELP PLEASE!!! 2007 dodge ram 1500
