Last edit by: IB Advertising
Browse all: Steering & Suspension
- Dodge Ram 2nd Gen Lift Kit Reviews
Review and comparison of top products.
2500 lift questions?
I am weighing my options for my new lift. (05 4x4 QC 2500 CTD) I've read countless discussions on 1500 lift/leveling kits, but not a lot on 2500's so I hope this isn't beating a dead horse. I only want 3"-4" of lift, as this is my tow rig and my DD, so reliability and ride quality are important.
Option 1:
I originally planned to just order a cheap spacer type 3" level kit for the front and 1.5" rear block kit, then wrap all four corners in Bilstein 5100's. cost ~$500-550
Option 2:
Then I found this kit with progressive rate coils and Bilsteins included for $1100 shipped
http://www.topguncustomz.com/Store/G...view=253320564
I don't think using the cheap leveling spacer type lift along with 5100's would give me a bad ride quality, but I am concerned about the death wobble issue/alignment problems . Will raising the front 3-4" using stock length control arms promote the death wobble issue I've heard so much about, or screw with handling? I know you would need longer arms for anything over 4", but not sure for under. The other issue with going the cheap route is are these spacers reliable for the weight of a Diesel 2500 and towing?
I know $1100 is on the high side for 3.5" of lift, and I have yet to find anyone running these progressive rate coils, so not sure how good they are, but that sounds like a great kit to me.
So what do you think, go with the cheap kit and put that extra $$ into other mods or spend it on the high priced kit? And please remember, this is for a 2500 CTD (heavy) and solid axle, not a 1500. I've had a lot of people offer advise, but they all own 1500's and have no experience with 2500's
Option 1:
Option 2:
I have done this to several rams I have owned in the past and all 2500's. Anything over a 3 inch spacer which is actually pushing it will require longer shocks and a 3 inch drop pitman arm and longer arms to position the wheels directly in the center like factory. The 3 inch spacer from topguncustomz.com is perfectly fine. I have used it many times over the years. And all you need in a once inch spacer for the rear. The threshold is 3 inches then everything has to be changed....
Please!
Also, at that price I would consider jumping up to a 5" kit. I don't think cost would be much more, as you are already replacing all the same components. And 5" still allows for a nice drivable truck without any major drive-train issues.
Trending Topics
Yea, i am definitely in the price range of bigger lifts, but I want to stick with 33" tires for now, I think anymore lift would look funny. But I am still on the fence, the more I research, the more I start to change my mind. I told myself I would not go overboard with this truck as I have in the past. My goals are a good dependable, good riding, tow rig with good mileage capability. I have a money pit already- 1 ton, coilovered, and linked Bronco, so don't want another one.... but maybe 5" lift and 35"s/36"s wouldn't be to bad
Hahahahahahah, ahh yes! The never ending modification saga. The bronc sounds bad ***!
Its just a simple 2" steel leveling kit, nothing else. I cant remember which brand it is. I had it laying around in the garage, and when I bought the truck I figured what the he!!, might as well slide it under there and level it off.
