Installing new cats
Installing new cats
Hey Folks Just picked up my new cats Walkers and they are bolt in. I have no issue with the manifold side but its the other end that has me scrsatching my head. Is this side weled in or can I use a muffler clamp? I have not yet looked under truck but the drivers side turns towards the passenfger side and ties in beside the passenger pipe. The other question is what size is the muffler clamp? I bleieve its 3 inch but would like to confirm
Last edited by Northern Goat; 03-27-2015 at 11:09 AM. Reason: Apparently I cannot spell
Sorry Brutal post. The cats are welded. I was just trying to envision how the 2 cats were tied togther. Now I see. Piece of cake. Wondering however if I am going to have to lower the sub frame to install the cat. Pretty tight in there. Shop I asked an estimate fro said you need to drop the subframe? Anyone have an issue with this?
So I installed new cats, (That was fun) cleared the codes and engine lgiht stayed on when i started truck. Went to part source P0420 has left the building but I now have P0032 which is voltage to high bank 1 sensor 1. I installed new 02's all around last year when she was running rough buyt did not address the 420 code (I know not good) anyways could I have fried that 02 sensor drving around with a semi plugged cat. I can tell the old one was quite restrictive as the motor sounds totally different now. Having a hard time telling if I am getting a rough accleration or im not used to the rumble. Goin got let the old girl cool off, check the cats for leaks, ensure the o2's are plugged in securely. Going to swap the front sensors and see if that code swaps to other side. If it doesn't swap over then I have wiring issue to sensors or the PCM is shot. I bought this truck used and the PCM has some yellow writing on it so I am going to assume its a used replacement. I have never had a vehicle that was such a pain in the ***.
Ok turned out I was working myself up reading all the tales of grief on here. Climbed under truck, went to swap the 02 sensors in the front and the drivers side came a part in my hand. Turns out the tab that lets you snap it in place is broken. so I put a zip tie around it tightened it up, cleared the code and started her up runs like a dream and no idiot light. hopefull it does not come lose again otherwise need a new connector spliced in and that should be a treat with the amount of room in that area. So happy I am done with that crap. moral of the story and I hear this all the time. check the obvious stuff first and dont assume its going to be worse case scenario. I'm my own worst enemy.
Hey Folks Looks like I planned the victory parade too soon. The Damn Nab #T&@$# light is winking at me again, This time P0404 EGR valve. I replaced this 3 years back but still drove around with a sludge plugged top end, a plugged cat so i am thinking i may have plugged this puppy right up. At this point i have rebuilt top end, replaced cats ,02 sensors done a year or so back and seem to be working for me. Seems like emission **** is failing one after the other.
I hear the pipe that goes from the EGR to the intake manifold could be grimy and I should clean this pipe up with carb cleaner? Does it disconnect from the manifold side easily or whats the deal.
I still have a dud alternator (bearing acts up) and when i start the truck in the morning the gauge crawls up to charging (Almost hesitates) instead of jumping right up upon start. Going to change alternator and possibly the PCM is sensitive due to irregular power from alternator? Just thoughts that bounce around in my head.
As for the EGR replacement do I or do I not need to have PCM re-flashed? Seen so many answers on this topic its hard to tell whats the fact and what is crap? As always I am appreciative and in awe of some of you folks knowledge on these trucks. Its impressive to say the least.
"What say ye oh wise ones"!
