Old 08-12-2015, 02:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
Print Wikipost
How To: Install Mopar Side Steps
Old 05-15-2009, 11:12 AM
Ironsides's Avatar
Ironsides
Ironsides is offline
Default How To: Install Mopar Side Steps
I installed by Mopar Side Steps a few days ago, and I captured most of the install with pictures. Below are those pictures, with some basic installation instructions.
You will need to install 12 Rivnuts.
This is supposed to be accomplished with a special Rivnut Compression Tool.
But you can make your own tool for about $3 in nuts and bolts. What you need
M8X1.25 bolt, at least 2 inches long
M8 nut
M8 washer
For tools, you will need a half inch wrench, to drive the nut, and whatever tool is required for the bolt. In this instance, a 6mm allen wrench.
A ratcheting closed wrench like the one shown will make the job easier
Assemble the bolt, nut, washer, and first rivnut as shown
This assembly will go into one of the 12 holes in the body. The holes are hexagonal, in pairs, on the inside lip of the body, at the front, middle, and back of the cab.
The tape above the 2 holes will be removed once both rivnuts are installed. The hole that the tape covers is used to hang the running boards.
Put your tools in place.
You need to hold the bolt in place, don't allow it to town, and also push in towards the hole, to keep the rivnut seated. Turn the nut clockwise. This will collapse the 6 walls of the rivnut. Keep turning, you'll know when to stop. Turn the nut counterclockwise a half turn, and then back the bolt out of the rivnut. This is the end result.
Insert the other 11 Rivnuts the same way. The rivnut installation is the hardest part of the whole install. It takes about 10 minutes to do the rest of it.
Each side step has 3 mounts, and each mount has a small tab that sticks out. These tabs go into the holes that were covered with tape before. The steps will just hang there. Once they're hanging, and adjusted front to back to line up the holes with the rivnuts, install the bolts. The bolts require a 13mm socket wrench.
This is the finished product.
Old 05-15-2009, 12:15 PM
navyr6's Avatar
navyr6
navyr6 is offline
nice write up, will be very useful when i get my side steps
Old 05-16-2009, 02:31 AM
Smile's Avatar
Smile
Smile is offline
perfect...i'm gonna install mine this weekend
Old 05-16-2009, 07:44 PM
72combo's Avatar
72combo
72combo is offline
Anyone have any rattle or squeak issues with these and what did you do??Pics if possible?
Old 05-16-2009, 08:08 PM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork
BubbaRadioNetwork is offline
No problems with my factory installed ones.
Old 05-16-2009, 08:34 PM
mike2810's Avatar
mike2810
mike2810 is offline
I have not had a problem with rattles/squeeks with the factory bars.
Nice write up Ironsides. Great jig for installing the rivnuts. I made the bars as part of the deal, so the dealer installed mine.
Old 05-17-2009, 12:01 AM
72combo's Avatar
72combo
72combo is offline
Ya dealer installed mine too but they could not fix the squeak. I fixed it.
Old 05-17-2009, 12:41 AM
Smile's Avatar
Smile
Smile is offline
man...i should have read this more carefully....i did not install the rivnut...i just started to bolt it on...it kinda work....rivnuts got mangled...so i came back and carefully read your post, made two homedepot trips and tried to fix them...i got two rivnuts to look right...the rest of them are mangled, but it still works.
i'm thinking if you placed a washer behind the L bracket you could just bolt it straight up without having to precompress the rivnut...because as you turn the bolt it will compress the rivnuts on it's own.
at first i thought the mopar side bar was straight...but once installed i noticed one side bends in and the other side is straight....which way does it go? i will finish tomorrow and post some pics.
Thanks ironsides for your write up...it saved my ***!!!
Old 05-17-2009, 01:06 PM
Smile's Avatar
Smile
Smile is offline
do u turn the bolt or the nut to put the rivnut in?
Old 05-17-2009, 01:48 PM
Soop's Avatar
Soop
Soop is offline
Looks good! No noise with mine...looks like it was not a major hassle. Probably should have installed mine and saved a few bucks. Dealer install was less hassle for me, though.
Quick Reply: How To: Install Mopar Side Steps
