Oil Change at 2500 Miles?
Old 03-26-2009, 08:02 PM
Thatmarkguy's Avatar
Thatmarkguy
Thatmarkguy is offline
Default Oil Change at 2500 Miles?
I heard a ding when I started my truck and noticed that I have a message. It says "Oil Chang Due". I've only got 2500 miles on the truck. I hope that this is not something typical of this truck. Maybe it knows that this is the first oil change and I should change it early?
Has anyone else had their oil change message come up this early?
Old 03-26-2009, 08:27 PM
capsfloyd's Avatar
capsfloyd
capsfloyd is offline
Mine did the same , changed it today with 2900, will probally go to 7900 on the next [5,000]
Old 03-26-2009, 08:28 PM
jeremys88's Avatar
jeremys88
jeremys88 is offline
I had my oil changed at 4000 miles and i had never gotten the message before, but figured i should do it anyway...then at 5800 miles i got a oil change message so just to be safe i changed it at 6000. weird.
Old 03-26-2009, 08:29 PM
mike2810's Avatar
mike2810
mike2810 is offline
Do you take a lot of short trips, start the truck many times during the day? Does your oil look dirty? If not, you could reset the system. Excerpt from the manual.
CHAngE OIL
Your vehicle is equipped with an engine oil change indicator system. The
CHAngE OIL message will flash in the instrument cluster odometer for approximately
12 seconds after a single chime has sounded to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle-based, which
means the engine oil change interval may fluctuate dependent upon your personal driving style. Unless reset, this message will continue to display each
time you turn the ignition switch to the ON position. To turn off the message temporarily, press and release the Trip Odometer button on the instrument cluster. To reset the oil change indicator system (after performing the scheduled maintenance) refer to the following procedure. 1. Turn the ignition switch to the ON position
(Do not start the engine). 2. Fully depress the accelerator pedal slowly three times within 10 seconds. 3. Turn the ignition switch to the OFF/LOCK position.
NOTE:
If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary repeat this procedure.
Old 03-26-2009, 09:00 PM
wmichell227's Avatar
wmichell227
wmichell227 is offline
I'm glad I'm not the only one who had to change their oil at 2500 miles. I was worried their was something wrong with my truck......
Old 03-26-2009, 09:28 PM
sarguy01's Avatar
sarguy01
sarguy01 is offline
I am coming up on 2100 miles and will know soon. I do mostly city driving.
Old 03-26-2009, 09:44 PM
Thatmarkguy
I drive about 130 miles each day, but the last 30 are in stop and go freeway traffic. I checked the oil, it's up to the correct level and it's not even dirty yet. I think I just going to reset the message and just change it at 5000 miles and then reset the oil change indicator then too.
Old 03-26-2009, 11:24 PM
ShirtaDay.com's Avatar
ShirtaDay.com
ShirtaDay.com is offline
Hmm.... approaching 2,000 and nothing yet, but should know soon. I hope this doesn't continue every 2,500 miles or so, especially if the oil really does look clean.
Old 03-27-2009, 01:00 AM
Helevitia's Avatar
Helevitia
Helevitia is offline
Mine showed up at 2500 as well. I changed it at 3000.
Old 03-27-2009, 09:10 AM
BrianLI's Avatar
BrianLI
BrianLI is offline
No oil light for me but change my oil at 2000 miles. Put Mobil 1 in. 7 quarts baby!!!
Quick Reply: Oil Change at 2500 Miles?
