Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
6x9 door speakers, What fits?
Old 12-21-2009, 01:24 PM
dsertdog56's Avatar
dsertdog56
dsertdog56 is offline
Default 6x9 door speakers, What fits?
I have a blown front door speaker and need to replace them. Can anyone who's installed front 6x9 speakers tell me what fits and what doesn't? I need to be able to roll down my windows.
Thanks!
Old 12-21-2009, 01:41 PM
casper3380's Avatar
casper3380
casper3380 is offline
go to crutchfield, they will give you the depths necessary. i had Polk db690 in mine before i went to the morels. they can help you there.
Old 12-21-2009, 02:02 PM
dsertdog56's Avatar
dsertdog56
Thanks...I should have mentioned that I went to Crutchfield and plugged in my vehicle.
That brand and model of speaker you owned didn't come up. The only speaker they listed was a brand I'd never heard of.
Which is why I posted here, I was hoping to found something I could purchase locally. I've noticed that most boxes don't have the physical specs listed on them.
Old 12-21-2009, 03:48 PM
squatchie16's Avatar
squatchie16
squatchie16 is offline
Just about any 6x9 should fit depth wise, but if you arent sure take the stock one out and measure how deep the new speaker can be with the window down and then go to a shop with those dimensions.
Old 12-22-2009, 04:00 AM
SilentRamAD's Avatar
SilentRamAD
SilentRamAD is offline
You can always fab up a spacer out of MDF or buy one through searching We have plenty of room between the speaker and the door panel.
Old 12-28-2009, 06:36 PM
moosefire66's Avatar
moosefire66
moosefire66 is offline
I have infact seen some people take some mdf, or some sort of spacer, and space them out. It still fits in the doors, and you dont have to worry about your depth.
Old 01-13-2010, 12:14 PM
zierbox's Avatar
zierbox
zierbox is offline
The factory 6x9 cut-out in the door is actually small
All most all aftermarket speakers will not mount flash in the door with the factory hole
A mounting ring will be required unless you cut out the hole
The factory 6x9 speakers have a small black plastic ring around them to allow them to fit the smaller hole. This ring doesn’t work well for aftermarket type 6x9 speakers
Old 01-13-2010, 12:16 PM
zierbox's Avatar
zierbox
zierbox is offline
Old 01-14-2010, 10:04 PM
dsertdog56's Avatar
dsertdog56
Zierbox, thanks for the help!
That door doesn't look like mine, but you are correct. I had to fab a spacer.
The stock speakers had a 2.5 inch depth and no spacer behind them. But my new speakers measured 3 inches.
So I recycled my old speaker grill and cut all the center out, leaving a perfect spacer ring for my new speaker.
When I installed the door panel, the speaker bubbled it out a bit. I may heat the panel and try to warp it so there isn't as much pressure on the tweeter mount. The bulbous look won't bother me.
I'm happy to have a properly functioning stereo again. I'll do the other door next week if the weather holds out. Even though I used rather inexpensive aftermarket speakrs, there was a decent improvement in sound quality. I may have to to do my quad doors!
Thanks again for your help!
Old 04-23-2010, 04:50 PM
avp0713's Avatar
avp0713
avp0713 is offline
Question: The doorpanel speaker grill on the OUTSIDE of the doorpanel is very large and looks sturdy enough. Can I surface-mount an 8" speaker on this doorpanel? Has it been done before.
Please do not laugh at my suggestion.... people used to laugh at me all the time in 1989 when I installed a Casio LED TV on a gooseneck in my Corvette. Now it's "all the rage".
Quick Reply: 6x9 door speakers, What fits?
