Drive cycle for a 98 G. caravan?
I got a "not ready" at the emissions test. It has been over a month since the battery has been out. It should have completed a drive cycle by now. I can't find the exact drive cycle in the OM, repair manuals or online. Does anyone know it? 98 G. Caravan 3.3 fwd
RE: Drive cycle for a 98 G. caravan?
It has been well over 500 miles now. Their has been mountain driving, flat land and lots of city driving. I did read something about the temp needing to be around 170, the van usually stays right in the middle. In the article they had to put the van on a lift, run it up to 55 mph for 5 min and let coast to an idle. [/align]
ok so that means that none of the tests have run. Yor adptive numerator more then likely has not been learned. Use the obd reader and clear the codes and odb info drive 10 miles in traffiic then drive for a few days check with the reader again and see what has been learned. U only need 3 of 4 to pass your emissions test
Trending Topics
Well, I did the battery, erased the codes, and took it for a 30+ mile drive. I tried to do the 55mph down to a idle a few times. Irescanned and only get one not ready,the heat 02. That one was ready last time, but I will try to take it through emissions once more.[/align]
this is all i have found so far. 1 drive cycle for odb2 reader for chrysler.
Fuel tank
half full.
Cold start and idle 5 min.
Drive with steady throttle 55 mph for 8 minutes. Do not exceed 60mph.
Park and idle for 3 minutes.
Resume driving at steady throttle 35mph 3 minutes.
Stop engine shut off for 10 minutes.
Fuel tank
half full.
