power window passenger side not working
Old 07-16-2007, 04:31 PM
adan's Avatar
adan
adan is offline
Default power window passenger side not working
In my 2002 Dodge Caravan power window stay in closed position, I cannot open it. Passenger side window working OK. Haynes manual - schematic shows separeted fuses for each window as located in junction box under instrument panel. I was not able to find this box and fix problem. May be this manual is not correct. Any help apreciated, thanks.
Old 07-16-2007, 04:47 PM
Dodge Tech's Avatar
Dodge Tech
Dodge Tech is offline
Default RE: power window passenger side not working
hold the switch down and smack on the door panel with some force. If it starts to move u need a regulator and motor assembly
Old 07-16-2007, 06:39 PM
adan's Avatar
adan
adan is offline
Ithink I need correct orygial factory electrical schematic for power windows system for Dodge caravan SE 2002.
Old 07-16-2007, 07:32 PM
Dodge Tech's Avatar
Dodge Tech
did u do as i asked or do u just want to mess around with the wires and stuff??
Old 07-20-2007, 02:08 PM
Radman's Avatar
Radman
Radman is offline
adan, Dodge Tech is correct as to what he suggested to do. BTW, it's NO fun to change that
regulator/motor assembly either! Price will make you wish you would have bought the old
crank up windows IF it even can be bought that way.
Good luck...
Old 07-20-2007, 07:40 PM
kh1p3h's Avatar
kh1p3h
kh1p3h is offline
Just replaced both regulators for my 97 GC. Around 160$ ea special order from Autozone. You willend up wanting to pull the door panel to check voltages through the switch ifthe problem is not immediately obvious. Odds are the cables are snarled inside the regulator if the window does not want to lower (I've never been able to repair this kind of damage). When the cables or connectors break the window typically drops to the bottom of the rails(If the cable has ripped out of a guide you may be able to repair it) These repairs are not cheap at the dealer or the auto glass places. I approached the repair as a two part process. One afternoon of investigation and one of repair after repair parts had been procured. It was a pain, but you can do it with some patience - I'm no genius.
Old 09-18-2007, 03:19 PM
kitcat555's Avatar
kitcat555
kitcat555 is offline
Default RE: power windows not working
Sometimes the passenger windows wont work and the driver has to control them.The button is up which allows the passengers to control their own window and still they can not. Nothing else electrical is having problems. Can you tell me what is wrong?
Old 09-18-2007, 10:23 PM
DavidMichael's Avatar
DavidMichael
DavidMichael is offline
Pry the switch out of the door panel and wiggle the plug to freshen the connection. it worked for me. Same van, same window, same problem. Fixed!
Old 09-18-2007, 11:05 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
All caravans have window regulator problems. dodge tech has it right, take the door panel off and hit the window motor and hold the button down. It don't get any easy than that. If the motor starts working leave it up until you can replace it. And you try prying switches out you could end up replacing a door panel too.
Old 09-19-2007, 12:25 AM
next2pool's Avatar
next2pool
next2pool is offline
Most of these problems are with the motor and not the regulator. The motor can be replaced without the regulator, but they are a bit pricey. You can find them for about $45 new, or go to a junkyard. Usually the brushes are dirty or worn out. I just opened up my door and pulled the motor housing off the motor/regulator assembly and sprayed it out with brake cleaner--a lot of carbon from worn brushes came out and it now works great. I do think that in the long run I'll need a "new" junk yard motor for $10 out here in AZ.
Quick Reply: power window passenger side not working
