2008 Grand Caravan sliding door question
Hi all,
Just took home a very nice 2008 Grand Caravan on Saturday but have a question about the sliding doors. On some of the models we checked out, a quick tug on the handle would open the door but on the one we got, if you pull the handle, the motor doesn't open the door but the door opens and closes automatically with the remote and with the buttons inside. Is there a way I can make mine slide open automatically with a pull of the handle?
Thanks.
Dave
Thanks.
Dave
on
I belive dave saying is, when he pull on the sliding door handle to open. The motor doesn't take over to open the door the rest of the way. Dave you can only open the doors with the remote or buttons inside the van, You also notice the 4way flasher blink when the sliding doors open. This is normal.
Trending Topics
08 Caravan sliding door problem
When the temp hit 10 degrees, I opened my 08 caravan drivers side manual sliding door. It stuck a little but with a slight pull the door opened. The door has not closed properly since. It latches but stays popped about 1/2 to 3/4 inches open. I can push in into the closed position but nothing catches and it bounces back to the popped position. Interior lights stay on and the dash indicate an open door. Dealer wants $100.00 just to look at it than of course parts and labor to repair. Does anyone have an idea on what I can do to fix?
The following users liked this post:
Nick Seabasty (02-14-2021)
Try close the latch with a screw driver, see if it latch properly. And try some WD-40, compare it to the other door. If the latch works fine,hook on the body side for mis-alignment. Also check the sliding door hinge at the bottom of the door, sometimes bolts gets loose down there and jam the door. Use the other "good door" as a reference.
I think the minivan has a latch in front and back for each door, check both. And if you do end up needing a latch, they are pain in the *** to replace...
yeah, i recommend you to take it to someone else too. If it is something that takes 2 minute to look at and figure out what's wrong, i hate to charge ppl $100 for it.
