Battery Drain
Battery Drain
During the past 2 weeks I have had the battery drained for about 5-6 times on my Dodge Grand Caravan -2005.
Had the battery, alternator and starter tested by AAA and all came out fine.
Has anybody else run into this situation before?
Any suggestions to help resolve this would be greatly appreciated.
Thanks in advance!
Thanks in advance!
RE: Battery Drain
With key off, test each of the fuses for power drain with a test light. There are a couple circuits (for memory purposes) that always have power, but you might find one that is draining when it is not supposed to. A lot of times this iscaused by corrosion in the harness and it going to ground.
RE: Battery Drain
I did the drain test this weekend and found nothing.
I looked for corrosion and could not find any. I will keep looking for corrosion. Any suggestions in this area to find the corrsion or is it going to be like looking for a needle in the haystack?
Thanks for all your help!
