belt squeal
Old 01-16-2017, 02:26 PM
cummins 6.7's Avatar
cummins 6.7
cummins 6.7 is offline
Default belt squeal
alright guys im in a rut
i have a 2010 dodge ram 6.7 cummins 2500
it began to squeal and power steering went out, fixed that.
couple weeks later it squealed and belt was bad, fixed that.
couple weeks later it started squealing again, changed belt tensioner assembly and idler pulley, still squealing.
i checked water pump and alternator and all is good
mother f***** wont quit squealing
idk what else to do
Old 01-16-2017, 05:50 PM
p38251's Avatar
p38251
p38251 is offline
Pull the belt. Spin each pull by hand. If it feels ruff maybe the issue. Belts squeal because they are slipping. Any leaks? Coolant? PS fluid? Oil?
Old 01-16-2017, 06:06 PM
cummins 6.7
no leaks
all pulls spin freely
no grinding sounds from pullies
luckily i called autozone and they are exchanging this belt, incase of a defective belt
so lets see what happens after in get the belt
Old 01-16-2017, 08:12 PM
p38251's Avatar
p38251
p38251 is offline
IMO I would buy a good quality belt.
Old 01-16-2017, 08:17 PM
cummins 6.7
so i put in the new belt and no squeal.... but, when i rev up the engine it sounds like its gonna squeal.
so something has to be going bad.
ive checked all pulleys and cleaned them
what i did notice with the old belt is that when the a/c is running the belt quits squealing when the compressor engages and then squeal again after it disengages
so does that mean a/c is goin bad? cause the pulley on it was good as far as my physical inspection went
Old 01-16-2017, 10:29 PM
p38251's Avatar
p38251
p38251 is offline
Does the ac clutch feel loose? It's possible it's going? Did the old belt look glazed?
Old 01-17-2017, 12:12 AM
cummins 6.7
i checked the compressor pulley and its good
i turned the clutch and it feels tight, not like its busted
the old belt was a little glazed not sure why since it was brand new
duralast belt
Old 01-17-2017, 02:11 PM
p38251's Avatar
p38251
p38251 is offline
Fire it up and see if one pulley appears to be spinning slower than the others. feel the alternator, ac compressor when running. See if you can feel an issue.
Old 01-17-2017, 02:15 PM
cummins 6.7
ill do that
ill get back to u
thnx
Old 01-17-2017, 03:22 PM
p38251's Avatar
p38251
p38251 is offline
N.P. Hopefully you will find it.
