2001 trans question
Old 03-16-2015, 07:27 PM
hoodjaray's Avatar
hoodjaray
hoodjaray is offline
Default 2001 trans question
hi all, need a few answers for my problem. 2001 dodge 2500 van with a jasper trans which shifts and sounds great still and had fluid changed and bands adjusted a year ago has just started to have a problem. When i first start to drive it and go slow everything shifts fine but after 10 mins or so , say from a red light the van shifts into 2nd and then has a hard time shifting into third unless i go real slow and then it catches shifts into other gears and downshifts no problem when slowing down. By the way replaced pcm 6 months ago and problem just started a week ago. Any ideas? Thanks
Old 03-26-2015, 09:09 PM
hoodjaray's Avatar
hoodjaray
Default trans update
got code p1756 other day hope it's governor or transducer
Old 03-26-2015, 11:47 PM
funair02's Avatar
funair02
funair02 is offline
Old 04-01-2015, 08:21 AM
blackvan's Avatar
blackvan
blackvan is offline
"has trouble shifting into other gears": do mean its shifts abruptly, tires chirp? or never shifts at all? Big difference. I might be able to help if you are experiencing late hard shifts otherwise I think you are looking at a total rebuild. Might have to take advantage of that expensive Jaspar warranty in that case.
Old 05-07-2015, 05:45 PM
hoodjaray's Avatar
hoodjaray
Default trans fixed
replaced governor and transducer parts were 110 amazon with filter etc plus fluid. Trans place wanted 750 i was done in 2 hours
Old 05-07-2015, 08:35 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
Awesomeness!
Old 05-12-2015, 06:24 AM
blackvan's Avatar
blackvan
blackvan is offline
So just to clarify, your $3000 Jaspar rebuilt transmission was installed with a transducer and governor pressure sensor which failed within what time frame?
Old 05-12-2015, 06:36 AM
hoodjaray's Avatar
hoodjaray
thanks blackvan for your interest. My jasper trans has 120,000 miles on it and is running strong again
Old 05-17-2015, 05:04 AM
blackvan's Avatar
blackvan
blackvan is offline
Sounds about right. The solenoid and transducer in my 46RE failed at around 116k.
Thank you for taking the time to update us as this information is extremely helpful.
Quick Reply: 2001 trans question
