code po703
code po703
im getting a code,brake switch b circuit malfunction...when trying to use the cruise control it wont ingage,i would clear the code and it would come back in a week and it doesnt come on when in driving just when i start the car up,had mechanics look at and the cant find the problem they say
Code p0703 is a failed brake light switch, which i believe could also disable the cruise control much like the clutch switch in a manual will disable cruise control if the clutch is pressed.
http://www.autozone.com/autozone/cat...p+Light+Switch
Do your brake lights work?
What stratus do you have coupe,sedan, 3.0L v6 (re bagged eclipse)
Any symptoms other than intermittent loss of cruise control?
Do me a favor next time the code sets go check your brake lights see if they are working. The switch cost like 20 bucks. It is located on the brake pedal, it will either be in front of or behind the pedal at the top. It will have a plunger that contacts the pedal, and an electrical pig tail. usually you just twist it and pull it out kinda like a headlamp.
Sometimes it isn't a plunger it's a rheostat ( hard to explain on here but it's a variable resister with a pin that follows a wheel and at certain points has a certain level of resistance)
click on the link I gave you that should be your part.
Trending Topics
Ill give you the short version, DTCs (Diagnostic trouble codes) are set when a certain condition is met, it is different from car to car and code to code. If the ECU detects a fault it sets a pending code and once the fuel has happened for long enough or enough times in some certain amount of time it will illuminate the check engine light and set the code
