check engine light after cold air in take install
Old 03-13-2009, 07:17 PM
TugsQuad's Avatar
TugsQuad
TugsQuad is offline
Default check engine light after cold air in take install
Hey all
I have a 08 Ram 4.7 Flex Fuel . I Installed a new cold air intake with K&n filter Why do i have a check engine light on I didnt remove any sensors How can I turn it off with out gettin a scanner Theres nuttin wrong with it
Thanks
Old 03-13-2009, 07:30 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Where is your AIT (air intake temp) sensor at and was it moved and it is still connected?
Old 03-13-2009, 07:48 PM
TugsQuad's Avatar
TugsQuad
TugsQuad is offline
attached to plastic connector Never had to touch it Thats whats confussing me
Old 03-13-2009, 08:24 PM
04-fourseven's Avatar
04-fourseven
04-fourseven is offline
Go through and double check EVERYTHING AROUND THE INTAKE. You might have bumped something while installing, or maybe something came loose after your test ride at WOT. Oh common, I know when i got my stuff in, the first straight away was WOT. hahahaha
Just check and double check.
Old 03-13-2009, 08:42 PM
ramracing4.7ltr's Avatar
ramracing4.7ltr
ramracing4.7ltr is offline
if you dont find anything disconnected or unplugged...i hear to try this and disconnect your negative wait 10 sec reconnect and it should be gone...not sure if thats right but i would try it!
Old 03-13-2009, 08:44 PM
bdhuntr's Avatar
bdhuntr
bdhuntr is offline
I don't know what K&N's instructions say, but the instructions with my Airaid CAI said to pull the PCM fuse before installation and reinstall it afterwards, as the increase in airflow would probably cause a CEL.
Pull the PCM fuse and leave it out for a few minutes; that will extinguish the CEL. Pop it back in and restart the engine and see what happens.
Old 03-13-2009, 10:45 PM
TugsQuad's Avatar
TugsQuad
TugsQuad is offline
Smile
Yes in deed the air was too rich . We pulled it and waited 30 minutes and all set . Thanks for the help Looks great and hope I gain a little with it
Old 03-13-2009, 10:52 PM
bdhuntr's Avatar
bdhuntr
bdhuntr is offline
Wow! I finally helped someone out here!
How does it sound when you get on it?
Old 03-13-2009, 11:12 PM
ramracing4.7ltr
lol ...excellent work
Old 03-13-2009, 11:16 PM
chambers's Avatar
chambers
chambers is offline
I wonder why some people get CEL's when they install CAI's and others don't. You would think going from stock to a lot more air flow we would all get them. My truck idled funny for a little bit until it got used to the extra air but not CEL.
Quick Reply: check engine light after cold air in take install
