Rera diff fluid
Old 01-19-2017, 09:09 AM
tsawuer1234's Avatar
tsawuer1234
tsawuer1234 is offline
Default Rera diff fluid
I have bben told to use 75-140 in the rear diff so many different charts is this the correct weight for non lds diff looks like approx. 2.5 qts ?
Old 01-19-2017, 11:24 AM
jkeaton is offline
Your owners manual should state the type and capacity.
Old 01-19-2017, 12:18 PM
tsawuer1234
That's long gone I bought the truck with 200k on it.
Old 01-21-2017, 12:00 PM
superbrowndude's Avatar
superbrowndude
superbrowndude is offline
75w140 with a limited slip additive or friction modifier
Old 01-21-2017, 02:56 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
75W-90 for light duty (no towing) or 75W-140 if you tow. Friction modifier only if you have LSD. I used -140 since I tow occasionally. 2 1/2 quarts sounds right. I added a deeper pan, so it took about 3 1/2.
Old 01-21-2017, 05:46 PM
tsawuer1234
Thank you for responding going to attempt to rebuild it m clips chewed up never heard any noise .
Old 01-22-2017, 07:01 PM
jfotsch's Avatar
jfotsch
jfotsch is offline
I lost my lsd diff last year. I never heard any noise but could swear it felt like it wanted to wheel-hop after getting hot and at certain speeds. I ended up having a Eaton Tru-Trac installed in place of the factory 9.25 lsd. Probably one of the best things I have done to the truck even though it was not something I had planned on doing. I stuck with the 355's because I did not want to do the front diff too. But now I am glad I did not go to the 392's like I was contemplating. The 355 gearing is perfect for my applications. I tow occasionally but not enough to warrant the change. I am also on 17's so that makes a difference.
I found a c-clip on my magnet and it was all downhill from there.
1500 bucks later I have a "REAL" locker that hooks like it should. I have to be careful when it is wet because I get sideways pretty fast.
I was told it was not that much of a difference in cost to rebuild or change it out so I opted to not have to go through that again. Mine started acting up at about 90k.
Wish you luck on the rebuild. Hope you can do it yourself. That type of precision work is way out of my league. Leave that one to the pros.
I am using Amsoil 75w-140 in my rear diff. I was told to use hypoid gear oil in the tru-trac but it is hard to find and so far no problems with the synthetic.
04 Ram 1500 Hemi 4wd QCSB, OEM off-road 17's, BFG-LT's, Airraid CAI, Cortex 3950, Magnaflow y-pipe, Detroit TT, Mag Hytec trans and rear, SRT A-pillar w/autometer trans temp, 190 t-stat, pwr stop drilled/slotted all 4, pwr wire, grnd TB
Old 01-22-2017, 08:22 PM
tsawuer1234
Do you have the part numbers for the carrier ?
Old 01-22-2017, 09:18 PM
jfotsch's Avatar
jfotsch
jfotsch is offline
Pulled out my receipt for the work done 12/15;
These are what they used on mine;
(913A368) 9.25 Eaton Detroit Trutrac
(YKC9.25-R-B) 9.25 Dodge Master Bearing Kit
(AK1559) 2 count 6408 & 8835S (1 side)
I changed the fluid every 2k with mobil 1 until it was clean (took 3 changes) and then went with the Amsoil. Also put a mag hytec cover on so I can keep an eye on it with the magnet. It holds a little bit more fluid; maybe 1/2 qt.
Hope this is of some help to you!
